can not find a variable or signal that tells me in what mode the machine is
  • ikkuh
  • ikkuh's Avatar Topic Author
  • Elite Member
  • Elite Member
19 Aug 2024 07:11 - 19 Aug 2024 07:19 #308119 by ikkuh
I am almost done with the qtDragon version of the rapidchangeatc toolchanger panel and M6 routines.
There is one (or two) things holding me up.
How can I tell from a macro (.ngc) file in what mode the machine is working?
With mode I mean, could be in toolchange mode, in idle mode and so on.
I have dust extraction coupled with the vfd.spindle-on signal.
#vacuum cleaner delay
addf vacuumOr2 servo-thread
loadrt timedelay names=timeDelayVacuum
addf timeDelayVacuum servo-thread
setp timeDelayVacuum.on-delay  0
setp timeDelayVacuum.off-delay 4
net spindle-on spindle.0.on => vfd.spindle-on
net spindle-on vacuumOr2.in0     # probably an M command
net coolant-flood  vacuumOr2.in1 # re use the flood button in qtvcp
net vacuum vacuumOr2.out
net vacuum timeDelayVacuum.in    # start the delay
net delay_sig timeDelayVacuum.out  [HMOT](CARD0).ssr.00.out-05[/code]
For the ATC to work the spindle has to turn. In my setup the dust extraction turns on when the ATC fires the spindle up. Lots of unnecessary noise.
I figure I can fix in this two ways, expand the above code with another OR2 and the Machine mode signal, or do it in the macro.
So my problem is I can not find a variable or signal that tells me in what mode the machine is.
Can somebody help me with that?
Last edit: 19 Aug 2024 07:19 by ikkuh. Reason: this editor sucks!
19 Aug 2024 10:05 - 19 Aug 2024 10:06 #308126 by MaHa
For this i use this hal pin:
[b]motion.motion-type[/b] OUT S32
These values are from src/emc/nml_intf/motion_types.h.0: Idle (no motion)
1: Traverse
2: Linear feed
3: Arc feed
4: Tool change
5: Probing
6: Rotary unlock for traverse
Last edit: 19 Aug 2024 10:06 by MaHa.
  • ikkuh
  • Elite Member
  • Elite Member
19 Aug 2024 12:40 #308133 by ikkuh
I used this:
addf toolchangeXor2 servo-thread
#net vacuum timeDelayVacuum.in
#net in-toolchange iocontrol.0.tool-change #in toolchange
net vacuum        toolchangeXor2.in0
net in-toolchange toolchangeXor2.in1
net toolchanging  toolchangeXor2.out
net toolchanging  timeDelayVacuum.in
But watching in Halshow the iocontrol.0.tool-change never changes. Will try your suggestion tomorrow, I did come across that motion-type but for some reason I didn´t want to use it.
Thanks!
Time to create page: 0.276 seconds
