Thanks for you reply & help with this.
This does indeed work.
I have been trying to set this up on a new machine, trying to remember all the configuring I did.
I was using the docs web page & noticed that it does not mention using a pause_pin.py file.
I found i had to add a line to the [DISPLAY] section...
USER_COMMAND_FILE = CONFIGFOLDER/pause_pin.py
That was not in the docs either.
linuxcnc.org/docs/devel/html/gui/qtdrago...xis_on_program_pause
However once this was added everything worked.
Now I'm trying to figure out how can I press the "OK" button on the popup dialog box remotely. Searching the internet makes me think this is not going to be so straight forward.
Any thoughts appreciated.
Alex
PS do you have a patrion page or some such as I would happily buy a Mars Bar & a double espresso coffee to say thanks
