AttributeError: 'VCPWindow' object has no attribute 'axistoolbutton_0'
05 Oct 2024 09:28 #311340 by wusel0464
Hello, Since today's update I've been getting this error message when starting up. The machine can be put into operation after confirmation. The previous version showed no problems.
Qtvcp encountered an error. The following information may be useful in troubleshooting:LinuxCNC Version : 2.10.0-pre0-3685-gcbfe160071
 Traceback (most recent call last):File "/usr/share/qtvcp/screens/qtdragon_hd/qtdragon_hd_handler.py", line 1100, in chk_use_virtual_changedself.w["axistoolbutton_" + i].set_dialog_code(codestring)~~~~~~^^^^^^^^^^^^^^^^^^^^^^^File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 498, in __getitem__return getattr(self, item)^^^^^^^^^^^^^^^^^^^AttributeError: 'VCPWindow' object has no attribute 'axistoolbutton_0'
Best wishes and have a nice weekend, frank.
05 Oct 2024 19:18 #311364 by cmorley
Thank you for the report.
I have pushed a fix to master.
The following user(s) said Thank You: wusel0464
