Retract no longer works after a while.
- wusel0464
- Thank you received: 7
05 Oct 2024 14:30 #311365
by wusel0464
Retract no longer works after a while. was created by wusel0464
Hello,
Something is wrong. If Qtdragon is running for a while, the retract function does not work for Z measurement or tool measurement. Z simply remains on the button in the triggered state. If Linuxcnc is restarted, it works again for a short while. Maybe there is a connection to the program length of the program being processed, approx. >50,000 steps. Qtdragon also feels a bit slow. BS and Linux CNC Version: 2.10.0-pre0-3685-gcbfe160071 up to date. I noticed the effect with the last version, but I suspected my wiring, but that was not confirmed.
Best regards, Frank.
- Thank you received: 2182
05 Oct 2024 16:51 #311370
Replied by cmorley on topic Retract no longer works after a while.
Could you post a sample long program to test with?
- wusel0464
06 Oct 2024 02:59 #311391
by wusel0464
Replied by wusel0464 on topic Retract no longer works after a while.
Hello,
no problem, I'm attaching it as a zip file.
It's not that long but this is where the problem occurred last.
I have another problem right now but I'm starting a new topic for it.
Sorry for my google English
Thank you for your efforts.
Kind regards, Frank.
- wusel0464
06 Oct 2024 07:02 #311398
by wusel0464
Hello,
I just ran a small program to test the change and the problem occurred there too, so the length of the program is not relevant. I'm attaching the changer routines.
Many thanks and best regards, Frank.
06 Oct 2024 08:06 #311406
Can you post your INI file?
- wusel0464
07 Oct 2024 10:11 - 07 Oct 2024 10:13 #311497
by wusel0464
Hello,
of course.
I now suspect that it could be the kernel. The description of a similar routine said that it was time-critical. However, the behavior is not really reproducible when measuring tools and workpieces.
In my test, it happened on the second attempt after restarting Qtdragon and then only after several attempts.
Unfortunately, I can't say for sure whether it could have been a while ago, as I didn't do anything in the summer and therefore only installed the last two Bookworm updates.
of course.
Last edit: 07 Oct 2024 10:13 by wusel0464.
10 Oct 2024 22:39 #311791
I don;t see any glaring problems in the INI.
You could try checking the system monitor to see if a particular program is stealing all the cpu cycles.
You could try a larger servo period to give the GUI more cycle time, but if this is a 'sometimes' problem, I would look at hardware: memory, storage medium, temperature, power supply.
- wusel0464
13 Oct 2024 03:45 #311940
by wusel0464
Hello,
Today I activated Kernel 6.1.0-11 Rt and immediately noticed something interesting that I hadn't paid any attention to before. My right mouse button, which I felt like I had to press for a long time before the context menu appeared, now works without any delays, Max Jitter is a good factor of 10 better.
Let's see what Qtdragon says about that.
I can't explain why the current kernel is so noticeable for me.
Best regards, Frank
Best regards, Frank
- wusel0464
25 Oct 2024 10:54 #313220
by wusel0464
Hello,
After I thought I had the solution, things turned out differently.
No retract for tool measurement or workpiece measurement.
Tried several times in a row, restarted Qdragon and it worked again. Unfortunately, the message that retrackt could not be executed is not really useful. But I can't provoke the problem either, at least I don't know how, since it occurs in the normal course of events.
- wusel0464
27 Oct 2024 09:32 #313302
by wusel0464
Hello,
Unfortunately the idea of debouncing the probe button didn't work either. I can press the emergency stop, switch the software off and on again, run the reference but nothing gets it working again, only closing Linuxcnc and restarting it. After that everything is back to normal.
Time to create page: 0.094 seconds
