Call custom Mcode from Gui Button
- csurimilan
27 Nov 2024 12:55 - 27 Nov 2024 13:21 #315401
by csurimilan
Call custom Mcode from Gui Button was created by csurimilan
Hello,
I have a question about coolant.
Im using costume made M-codes to controll the relays for my collant. (Air,flood,Mist => M100,M101,M102 and M105 turn off all)
I would like to know how can i address in the HAL file that if i press a button in the gui (qtDragon) that is turning on/off my coolant and of course i would like its working autoatically when the cnc is working. (Im using costume M-codes because im controlling more outputs)
net coolant-flood <= iocontrol.0.coolant-flood //here i dont know how can i add the M101
thank you
thank you
Last edit: 27 Nov 2024 13:21 by Aciera. Reason: Moved over here from Remora thread.
- Thank you received: 2177
27 Nov 2024 13:26 #315402
Replied by Aciera on topic Call custom Mcode from Gui Button
- Create a new HAL_COMMAND entry in the [HALUI] section of your ini file:
MDI_COMMAND = M101
- Make sure the [HAL] section of your ini file contains this entry:
HALUI = halui
Then connect the MDI_COMMAND in your hal file:
net coolant-flood => halui.mdi-command-00
Note that this will not work when a program is executing as this requires the controller to execute an MDI command.
MDI_COMMAND = M101
HALUI = halui
The following user(s) said Thank You: csurimilan
- csurimilan
27 Nov 2024 13:37 #315406
by csurimilan
Replied by csurimilan on topic Call custom Mcode from Gui Button
Its working.
how can i turn off.
Beacuse if i press the button its turning green and the output is true. But if i press the button again its not turning off.
how can i turn off.
28 Nov 2024 03:43 #315445
- Create a new HAL_COMMAND entry in the [HALUI] section of your ini file (below the one you created for M101):
MDI_COMMAND = M105
loadrt not
addf not.0
net coolant-flood => not.0.in
net not-coolant-flood <= not.0.out => halui.mdi-command-01
MDI_COMMAND = M105
loadrt not
addf not.0
- csurimilan
28 Nov 2024 14:26 #315489
by csurimilan
Thank you so much.
i just needed to add one little thing "addf not.0 base-thread" and with that adjustment its woking.
Time to create page: 0.187 seconds
