Qtgragon Versa Probe Bug ? probe_routines.py
- zieluch
- Thank you received: 6
30 Nov 2024 11:42 - 30 Nov 2024 11:52 #315639
by zieluch
Qtgragon Versa Probe Bug ? probe_routines.py was created by zieluch
Hi Guys,
I think I found a bug in the probe_routines.py for versa probe. When Trying to probe from outside from 4 sides in the current setup I was not able to make it working. ( I always had to probe very end X+ and Y+ with adequate searching distance). Not sure if this is happening only for me but but this was pretty anoying because even I found center I couldn't from ceter position run routine again to double check.
Someone might find this helpful i adjusted probe_routines.py file (/usr/lib/python3/dist-packages/qtvcp/widgets/probe_routines.py)
github.com/LinuxCNC/linuxcnc/blob/master...ts/probe_routines.py
line 1089replace with:line 1054replace with:
line 1089
aa = (2 * self.data_side_edge_length) + self.data_latch_return_dist + self.data_xy_clearanceaa = 2 * (self.data_side_edge_length + self.data_latch_return_dist + self.data_xy_clearance)aa = (2 * self.data_side_edge_length) + self.data_latch_return_dist + self.data_xy_clearanceaa = 2 * (self.data_side_edge_length + self.data_latch_return_dist + self.data_xy_clearance)
Last edit: 30 Nov 2024 11:52 by Aciera. Reason: code formating changes
- Thank you received: 2177
30 Nov 2024 11:53 - 30 Nov 2024 11:54 #315640
Replied by Aciera on topic Qtgragon Versa Probe Bug ? probe_routines.py
I fixed the formatting.
Maybe you want to file this as an issue or as a pull request on github?
Last edit: 30 Nov 2024 11:54 by Aciera.
- zieluch
30 Nov 2024 18:09 #315669
by zieluch
Replied by zieluch on topic Qtgragon Versa Probe Bug ? probe_routines.py
issue
github.com/LinuxCNC/linuxcnc/issues/3196
pull
github.com/LinuxCNC/linuxcnc/pull/3197
I home this is correct, if not please let me know.
pull
- Thank you received: 2181
01 Dec 2024 07:17 #315709
Replied by cmorley on topic Qtgragon Versa Probe Bug ? probe_routines.py
Merged. thank you.
Time to create page: 0.156 seconds
