camera resolution doesn' fit
- partec
- Thank you received: 27
06 Dec 2024 08:42 #316108
by partec
camera resolution doesn' fit was created by partec
- partec
06 Dec 2024 10:59 #316118
by partec
Replied by partec on topic camera resolution doesn' fit
It shouldn't be necessary to use Multimedia CHEESE for AXIS data logging, right?
- Thank you received: 2181
06 Dec 2024 11:53 #316120
Replied by cmorley on topic camera resolution doesn' fit
Do you mean the image is not the full tab width in Axis?
The following user(s) said Thank You: partec
- partec
06 Dec 2024 13:34 #316127
by partec
thanks Chris, it is none proportionality of the figure at all, there is no idea at the moment.
06 Dec 2024 14:24 #316132
x or y scaling needs adjustmenf -meaning a distorted shape (that's what it looks like)
You can set the scaling of x and y in 2.9.3 with the INI embedding line by adding something like this:
-o xscale=1.0 -o yscale=1.5
- partec
06 Dec 2024 14:33 #316133
by partec
that seems absolutely plausible, I would like to try it out later, thanks Chris
- partec
06 Dec 2024 15:32 #316138
by partec
strangely, the variation of the parameter is not relevant effective on the proportionality of the image
07 Dec 2024 14:02 #316211
Yes I can see there is a bug in the code. I'll fix it soon.
The following user(s) said Thank You: tommylight, partec
- partec
07 Dec 2024 16:40 #316216
by partec
You are welcome to know that I am extremely grateful for your extraordinary achievements here, I really enjoy using all of these great tools
07 Dec 2024 17:36 #316220
I just pushed the fix to 2.9 and master branch.
If you are using a released version, it wont come out till 2.9.4, but we could work around that if you need.
Time to create page: 0.215 seconds
