Tool offset problem with Qt
- Hastrh2o
- Thank you received: 6
24 Feb 2025 14:05 - 26 Feb 2025 08:24 #322486
by Hastrh2o
Tool offset problem with Qt was created by Hastrh2o
I'm trying to change tool offsets on the fly, in order to use a grinding wheel with two workplaces, one at the front to machine my part, and one at the back to refresh the grinding wheel with the diamond wheel. For other reasons (I have 4 axis, X, Z, U, W and two grinding wheels attached, one on X,Z and the other on U,W), I can't work with the tool diameter (since I have two different diameters).
So, I want to change from +X offset to -X offset when I work at the front or at the rear of the grinding wheel. And that's where I try to switch with G10 L1 P1 X[#5401] but it doesn't work. As it may come from my setup, I gone back to simulation sample configuration. It works in Axis simulation sample, but not in QtAxis simulation, neither in QtDragon. So it seems to be related to Qt.
This is working in Axis but isn't in QtAxis or QtDragon :
G0 G54 X0
M6T1
G43
G10 L1 P1 X10
G43 (here G54(X) is 10)
(debug,#5401) (show -10)
G10 L1 P1 X[#5401]
G43 (here G54(X) is -10)
(debug,#5401) (show 10)
This is working in QtAxis or QtDragon (double call to G10 ) :
G0 G54 X0
M6T1
G43
G10 L1 P1 X10
G43 (here G54(X) is still -10)
G10 L1 P1 X10
G10 L1 P1 X[#5401]
G43 (here G54(X) is still 10)
G10 L1 P1 X[#5401]
I don't understand why I need to call G10 twice in order it works. Since I want to inverse the value, I'm not really confident in calling twice the function...
Any idea on what's is going on ?
Regards,
Ronan
G0 G54 X0
M6T1
G43
G10 L1 P1 X10
G10 L1 P1 X[#5401]
G0 G54 X0
M6T1
G43
G10 L1 P1 X10
G10 L1 P1 X10
G10 L1 P1 X[#5401]
G10 L1 P1 X[#5401]
Regards,
Ronan
Last edit: 26 Feb 2025 08:24 by Hastrh2o.
- Hastrh2o
25 Feb 2025 07:59 - 25 Feb 2025 13:23 #322563
by Hastrh2o
Replied by Hastrh2o on topic Tool offset problem with Qt
I can store #5401 value in #myvalue variable and call twice G10 L1 P1 X[#myvalue], I will try this today.
If anybody has a way to understand what happened, I would prefer.
Last edit: 25 Feb 2025 13:23 by Hastrh2o.
- Thank you received: 2173
26 Feb 2025 06:35 #322656
Replied by cmorley on topic Tool offset problem with Qt
try opening Linuxcnc Status (settings tab right hand side 'status')
Look under G5x offset.
I bet that linuxcnc is using the right offset but qtdragon is reporting wrong on the offset page.
I assume you are referencing the offset page entries?
- Hastrh2o
26 Feb 2025 08:23 #322669
by Hastrh2o
I will check this afternoon. But since it's working after the second call at the same line, I doubt. I edit my first post to be more clear on the test I did.
- Hastrh2o
26 Feb 2025 21:11 - 26 Feb 2025 21:17 #322751
by Hastrh2o
I ran a linuxcnc 2.9.2 instance with axis in a virtualbox. I look at linuxcnc status.
One call to G10 L1 P1 X10 and G43 works fine. g5x_offset don't move, tool_offset is changing to X10.
The same test with qtaxis needs two call to G10 and G43 in order it works.
I managed to do my offset change on the fly with a numbered variable and two calls to G10, so it's not a problem anymore for me, but I think there's a bug to look at here.
Last edit: 26 Feb 2025 21:17 by Hastrh2o.
Time to create page: 0.226 seconds
