Indicators on Push Buttons
18 Mar 2025 12:13 #324192 by JT
Indicators on Push Buttons was created by JT
Chris,
How are you adding the indicator lights to the upper right corner of the push buttons in QtDragon?
JT
18 Mar 2025 12:40 #324194 by cmorley
Replied by cmorley on topic Indicators on Push Buttons
I have a mixin class that reimplements the paint event. It first paints the normal widget then adds indicator painting.
github.com/LinuxCNC/linuxcnc/blob/master...ts/indicatorMixIn.py
19 Mar 2025 10:55 #324282 by JT
Replied by JT on topic Indicators on Push Buttons
Thanks Chris, that's going to take a bit of study for me to break it down. Pretty cool stuff.
JT
19 Mar 2025 12:43 #324289 by cmorley
Yes action buttons are some of the most complicated code.
It does make buttons a little less boring :)
19 Mar 2025 13:40 #324294 by JT
I think it's pretty damn cool myself.
JT
25 May 2025 16:47 #329123 by CADdy
Replied by CADdy on topic Indicators on Push Buttons
Hi Chris,
how to install this widget? Only copy the file indicatorMixIn.py to /usr/lib/python3/dist-packages/qtvcp/widgets ? Can it then be used with Qt Designer?
Peter
26 May 2025 01:16 #329140 by cmorley
IndicatorMixin is not meant to be used directly. It is 'mixed in' with another button widget such as Qtvcp's PushButton widget or IndicatedPushButton widget
The following user(s) said Thank You: CADdy
27 May 2025 09:20 #329207 by CADdy
Thanks Chris, I thought that was a standalone widget. Thanks for the info.
Peter
Time to create page: 0.638 seconds
