Couldn't get the WARNING icon in LcncDialog
- millikari
- Thank you received: 3
31 Mar 2025 11:14 - 31 Mar 2025 11:31 #325379
by millikari
Couldn't get the WARNING icon in LcncDialog was created by millikari
Hi, I had a little trouble displaying the warning icon in a LcncDialog widget. I think it's caused by setting the default to INFO icon before checking WARNING and CRITICAL (dialog_widget.py in master 0fda49f):
Changing the sequence of the statements lets me choose also the WARNING icon.
Sorry, have some problems formatting the code passage in my message
# convert text descriptions to actual icons
if icon == 'QUESTION': icon = QMessageBox.Question
elif icon == 'INFO' or isinstance(icon,str): icon = QMessageBox.Information
elif icon == 'WARNING': icon = QMessageBox.Warning
elif icon == 'CRITICAL': icon = QMessageBox.Critical
self.setIcon(icon)Changing the sequence of the statements lets me choose also the WARNING icon.
elif icon == 'INFO' or isinstance(icon,str):icon = QMessageBox.Information
self.setIcon(icon)Sorry, have some problems formatting the code passage in my message
Last edit: 31 Mar 2025 11:31 by millikari. Reason: Hopefully now fixed the formatting
- snowgoer540
- Thank you received: 907
31 Mar 2025 16:02 #325408
by snowgoer540
Replied by snowgoer540 on topic Couldn't get the WARNING icon in LcncDialog
It might be helpful to know how you are calling it?
- millikari
31 Mar 2025 19:55 - 31 Mar 2025 20:01 #325424
by millikari
Replied by millikari on topic Couldn't get the WARNING icon in LcncDialog
Yes, I call it by connecting STATUS 'general' message and the ACTION.CALL_DIALOG:
A LcncDialog widget with matching launch-ID is defined in the ui-file. I have already checked whether the value of the 'icon'-variable is set correctly right before the statement I have shown in my first post (first code box). It's all fine. Looking at the original code, I think, because 'icon' is an instance of string in all cases, the 'WARNING' and 'CRITICAL' cases can never be reached. So I changed the sequence in order to give WARNING and CRITICAL also a chance getting active. Am I right with my consideration or have i missed something?
if STATUS.machine_is_on():
mess = {'NAME':'UNHOME_MSG', 'ID':'UNHOME_DIALOG',
'MESSAGE':'Really want to Un-Home?', 'TYPE':'YESNO', 'ICON':'WARNING'}
ACTION.CALL_DIALOG(mess)A LcncDialog widget with matching launch-ID is defined in the ui-file. I have already checked whether the value of the 'icon'-variable is set correctly right before the statement I have shown in my first post (first code box). It's all fine. Looking at the original code, I think, because 'icon' is an instance of string in all cases, the 'WARNING' and 'CRITICAL' cases can never be reached. So I changed the sequence in order to give WARNING and CRITICAL also a chance getting active. Am I right with my consideration or have i missed something?
Last edit: 31 Mar 2025 20:01 by millikari. Reason: Again formatting issues
- snowgoer540
31 Mar 2025 22:39 - 31 Mar 2025 22:58 #325431
by snowgoer540
I made a few minutes to take a look at this tonight.
I do see the behavior you describe, although the order is not the root cause.
In this line: github.com/LinuxCNC/linuxcnc/blob/bd9034...ialog_widget.py#L201
it's this part that is causing issue:
The icon value is set correctly to 'WARNING' on the go-in, but because but because icon is of type str, the second condition "isinstance(icon, str)" evaluates to True, and therefore never gets to check for 'WARNING'.
Perhaps it’s meant to be a catch all, in that case I agree it should move to last, but I want Chris to weigh in before I change it as I'm not quite sure of the purpose (if typo should we tell the user there’s a typo?).
elif icon == 'INFO' or isinstance(icon,str): icon = QMessageBox.Informationit's this part that is causing issue:
isinstance(icon,str)The icon value is set correctly to 'WARNING' on the go-in, but because but because icon is of type str, the second condition "isinstance(icon, str)" evaluates to True, and therefore never gets to check for 'WARNING'.
Last edit: 31 Mar 2025 22:58 by snowgoer540.
- Thank you received: 2181
01 Apr 2025 01:55 #325445
Replied by cmorley on topic Couldn't get the WARNING icon in LcncDialog
Yes its a catchall that should be at the end.
I think I added warning and critical after the others and didn't think of the logic.
Good eye gents!
Good eye gents!
- snowgoer540
01 Apr 2025 22:15 #325486
by snowgoer540
The following user(s) said Thank You: cmorley, millikari
Time to create page: 0.211 seconds
