Qt Designer QMainWindow slots
- Hastrh2o
- Thank you received: 6
02 Apr 2025 14:58 #325519
by Hastrh2o
Qt Designer QMainWindow slots was created by Hastrh2o
When I edited qtaxis.ui I found the new functions I added to the handler file in "signal editing / slot " panel. Now I add another function to the handler file and I don't recall what I need to do to find it in "signal editing / slot " panel... I know I could edit manually the ui file and that's work, but I prefer having it there.
Thanks.
Ronan
Thanks.
Ronan
- Thank you received: 2181
04 Apr 2025 18:31 #325702
Replied by cmorley on topic Qt Designer QMainWindow slots
Does this help?
linuxcnc.org/docs/devel/html/gui/qtvcp.h...qtvcp:designer-slots
The following user(s) said Thank You: Hastrh2o
- Hastrh2o
17 Apr 2025 08:34 #326512
by Hastrh2o
Replied by Hastrh2o on topic Qt Designer QMainWindow slots
At first not, but in fact, it help.
I thought there was a way to have all slots listed automatically from the handler file. In fact, the slots are listed once we add them manually as described in this help page.
Time to create page: 0.148 seconds
