Should I switch from AXIS to QtDragon?
- Hakan
- Thank you received: 454
17 Apr 2025 14:04 #326524
by Hakan
Should I switch from AXIS to QtDragon? was created by Hakan
Yes you should switch. At least try it.
- Thank you received: 4149
19 Apr 2025 20:07 #326731
Replied by rodw on topic Should I switch from AXIS to QtDragon?
its just all round better if you have a 1080p rouch screen, plus it adds probing and too handling if you have repeatable tooling.
it is very well documented
- Thank you received: 7484
19 Apr 2025 23:56 - 20 Apr 2025 00:04 #326742
Edit:
The evidence of the above:
forum.linuxcnc.org/show-your-stuff/32784...ofit?start=30#239606
Replied by tommylight on topic Should I switch from AXIS to QtDragon?
I have plenty, you are welcomed to use them, but i can not guarantee the quality! They do chew on everything in the shop though, seem pretty healthy by the looks and the speed they move through the shop.I have no quality mice available.
Edit:
Last edit: 20 Apr 2025 00:04 by tommylight. Reason: link
The following user(s) said Thank You: Hakan
- Hakan
20 Apr 2025 05:44 #326746
by Hakan
Replied by Hakan on topic Should I switch from AXIS to QtDragon?
Touch screen. Qtdragon and a touch screen.
One can get by without keyboard and mouse.
- Hakan
20 Apr 2025 16:09 #326771
by Hakan
Maybe you should get away from those mice, you see from Tommy what they can do.
I don't know if it is better with a mouse, Qtdragon is designed to allow the use of fingers, even thick fingers.
You can always try. Make a copy of your current config and experiment with QtDragon.
Get the QtDragon setup from the linux examples (simulator examples) and mix in your ini and hal files.
If you are able to do that you won't destroy the current config and you get a chance to try QtDragon on your machine.
20 Apr 2025 21:36 #326777
Anybody want a used but battle proven mousetrap I no longer have a use for?
I had one but I bought a better mousetrap and the offending rodent was dispatched in under an hour!
21 Apr 2025 22:49 #326848
Said cat is out of a job due to technology in the better mouse trap!Just buy a cat.
They're cute and they catch mice.
Time to create page: 1.320 seconds
