Manual Toolchange + Abs Z Probe (QtDragon)
- SanzuiWorks
- Thank you received: 4
21 May 2025 11:45 #328853
by SanzuiWorks
Replied by SanzuiWorks on topic Manual Toolchange + Abs Z Probe (QtDragon)
So far, this method is not working well.
Nothing happens when I load the NGC. For now, I would like to try a different method.
I am considering creating an action button that retrieves the first WSC from the loaded NGC and sends it to the MDI. ...
- MennilTossFlykune
- Thank you received: 30
21 May 2025 14:57 #328861
by MennilTossFlykune
Replied by MennilTossFlykune on topic Manual Toolchange + Abs Z Probe (QtDragon)
You can add this under StatCanon in qt5_graphics.py:Reading Work Coordinates When Loading a New NGC File
When loading a new `.ngc` file in LinuxCNC, is it possible to read the work coordinates at that stage? Since the G-code has not been executed yet, the work coordinates might not be applied.
Would it be possible to create a custom button, similar to "WCS Sync," that reads the `.ngc` file and sends commands like `G55` to MDI?
Has anyone implemented something similar, or does LinuxCNC provide a built-in way to achieve this? Any insights or suggestions would be greatly appreciated.
Thanks!
def set_g5x_offset(self, index, x, y, z, a, b, c, u=None, v=None, w=None):
interpret.Translated.set_g5x_offset(self, index, x, y, z, a, b, c, u, v, w)
g5x = {
1: 54,
2: 55,
3: 56,
4: 57,
5: 58,
6: 59,
7: 59.1,
8: 59.2,
9: 59.3
print(f"G{g5x[index]} on line {self.lineno}")Please Log in or Create an account to join the conversation.
- SanzuiWorks
22 May 2025 12:29 - 22 May 2025 12:55 #328910
by SanzuiWorks
MennilTossFlykune
Thank you for your advice.
I've been focusing on incorporating this all day today, but I still can't get out of the error. To be honest, I don't even know where I am now.
Last edit: 22 May 2025 12:55 by SanzuiWorks.
- SanzuiWorks
22 May 2025 15:58 - 22 May 2025 16:06 #328922
by SanzuiWorks
I’ve managed to detect WCS (G54–G59) from a loaded .ngc file and output it to the terminal.
To be precise, it prints the WCS to the terminal log.
But I haven’t yet succeeded in sending it to MDI to change the GUI WCS.
Code implemented inside qt5_graphics.py > StatCanon:
Sample G-code:
Terminal output:
As you can see, G54 appears at both the top and bottom.
This needs further filtering to ensure only the first actual WCS used in the program is considered.
g5x = {
1: "G54", 2: "G55", 3: "G56", 4: "G57",
5: "G58", 6: "G59", 7: "G59.1", 8: "G59.2", 9: "G59.3"
print(f"[DEBUG] {g5x.get(index)} on line {self.lineno}")
super().set_g5x_offset(index, x, y, z, a, b, c, u, v, w)Sample G-code:
G21
G90
G55
G0 X10 Y10
M2Terminal output:
[DEBUG] G54 on line 0
[DEBUG] G55 on line 3
[DEBUG] G54 on line 5As you can see, G54 appears at both the top and bottom.
Last edit: 22 May 2025 16:06 by SanzuiWorks.
- SanzuiWorks
26 May 2025 16:32 - 24 Jun 2025 13:57 #329166
by SanzuiWorks
I finally managed to implement this and it seems to work very well.
What it does:
- Detects the first G5x coordinate system (G54–G59.3) used in a G-code file
- Prints a debug log to the terminal: [DEBUG] G57 on line 4
- Sends the detected G5x via MDI so that the GUI updates to reflect the active work coordinate system
How I implemented it:
I added the following method to the StatCanon class in:
/usr/lib/python3/dist-packages/qt5_graphics.py
Notes:
- Make sure this method is placed inside the StatCanon class with consistent 4-space indentation.
- The initial G54 on line 0 and final G54 at the end (due to GUI reset) are ignored using: self.lineno > 0
- Only the first explicitly used G5x is applied via MDI.
- Verified to work reliably in QtDragon simulator config.
This improves usability by ensuring the GUI’s coordinate system matches what the G-code will actually use.
Tested with:
- LinuxCNC 2.9.4
- QtDragon (QtVCP)
- sim.qtdragon.qtdragon_tool_probe configuration
Let me know if this is helpful or if there’s a cleaner way to hook into the coordinate system logic.
What it does:
print("[DEBUG-TRACE] >>> set_g5x_offset() is running <<<")
g5x = {
print(f"[DEBUG] set_g5x_offset() called: {g5x.get(index)} on line {getattr(self, 'lineno', '?')}")
if not getattr(self, "g5x_mdi_sent", False):
if self.lineno > 0:
self.g5x_mdi_sent = True
print(f"[DEBUG] Sending initial MDI: {g5x.get(index)}")
try:
import linuxcnc
c = linuxcnc.command()
c.mode(linuxcnc.MODE_MDI)
c.wait_complete()
c.mdi(g5x.get(index))
print(f"[DEBUG] Sent MDI: {g5x.get(index)}")
except Exception as e:
print(f"[ERROR] Failed to send MDI: {e}")
Notes:
Tested with:
- LinuxCNC 2.9.4
- QtDragon (QtVCP)
Last edit: 24 Jun 2025 13:57 by SanzuiWorks.
Time to create page: 0.284 seconds
