Moving from Axis to QtDragon?
13 May 2025 01:54 #328333 by tommylight
Replied by tommylight on topic Moving from Axis to QtDragon?
Those should be in the ini file, the DISPLAY and TRAJ sections.
  • Spyderbreath
  • Spyderbreath's Avatar Topic Author
  • Senior Member
  • Senior Member
13 May 2025 03:51 - 13 May 2025 04:04 #328342 by Spyderbreath
Replied by Spyderbreath on topic Moving from Axis to QtDragon?
Yes, I have looked in there and I only see max spindle override and max feed override. I do not see max velocity override or max rapid override. Not in my .ini file or any of the qtdragon .ini's. Maybe I should try and add those? Like MAX_VELOCITY_OVERRIDE =x.x and MAX_RAPID_OVERRIDE =x.x ?
Edit: And I just tried it, no change. Adding those into display with the feed and spindle did nothing.
Last edit: 13 May 2025 04:04 by Spyderbreath.
13 May 2025 04:51 #328345 by tommylight
MAX_VELOCITY on both.
  • Spyderbreath
  • Senior Member
  • Senior Member
13 May 2025 15:12 #328389 by Spyderbreath
That works. My confusion was thinking there should of been and _OVERRIDE function like rapid. Thanks, that solved several problems with my setup.
13 May 2025 15:29 #328394 by tommylight
You are welcomed, always.
Sorry for the short and lacking replies, but when i am busy i try to at least point to a direction.
Time to create page: 3.174 seconds
