QTDragon_hd with mechanical dial tool setter
- Spyderbreath
- Thank you received: 9
26 May 2025 18:16 - 27 May 2025 09:23 #329176
by Spyderbreath
QTDragon_hd with mechanical dial tool setter was created by Spyderbreath
Never mind, stupid question. All attempts result in massive errors or a segfault crash of LinuxCNC.
Thanks for looking.
Thanks for looking.
Last edit: 27 May 2025 09:23 by Spyderbreath.
- Thank you received: 2181
27 May 2025 13:00 #329218
Replied by cmorley on topic QTDragon_hd with mechanical dial tool setter
QtDragon has not put any extra effort to facilitate a manual setter, but I don't see why you couldn't use one. Could you describe the process you wish to use for setting tool length?
- Spyderbreath
29 May 2025 15:46 #329373
by Spyderbreath
Replied by Spyderbreath on topic QTDragon_hd with mechanical dial tool setter
Apologies for not responding sooner. Yes, I would like to be able to set my tool length offsets by lowering Z until the dial on the analog gauge reads 0 and register that position in the tool offsets. Like in Axis this would be the point where one would, as I understand it, press Touch Z in the gui, but there is no Touch Z button in QtDragon. Now I would of suspected that there might be some alternatively named button or a line of some mystical gcode that could be entered that would write the offset into the tool table, but after looking for days, I have found nothing that would explain how this could be done.
I know all my problems would be solved by just getting an electronic tool setter, but at the same time I am baffled by there being no example, or set of instructions that I could find, as to how to do the tool length offsets by hand and analog gauges. It's all push the button stuff and nothing I could find that helps someone understand what to do if there is no button to push.
Is there a specific reason why QtDragon does not have any plugin, addon, macro, or screen that would facilitate manual tool setting?
30 May 2025 02:42 #329389
No one has asked for a specific facility for manual tool setting, which would start with specific procedure. There are a few common tool length strategies.
'Touch Z' usually implies _coordinate_ touch off which QtDragon has buttons for (REF and ZERO).
For tool setting, you can of course manually change the offsets in the tool offset page but also when you are on the tool offset page, the 'HOME' buttons change to 'TOOL' buttons.
Pressing that button will give you several options for setting the tool offset.
- persei8
- Thank you received: 133
30 May 2025 19:04 #329404
by persei8
Replied by persei8 on topic QTDragon_hd with mechanical dial tool setter
The latest QtDragon version at github.com/persei802/QtDragon_hd has a button for using a manual tool gauge. You use it by selecting Manual Tool Gauge in the Settings page, then lowering the tool until your gauge reads 0 and then press the Manual Touchoff button.
Jim
Jim
- Spyderbreath
03 Jun 2025 12:30 #329595
by Spyderbreath
Thank you for your input, but at this time nothing I seem to do works out right. I clearly am missing something but I do not know what that might be. It's wonderful that a new version has a button for using a manual tool gauge, however after trying to follow instructions from this post - www.forum.linuxcnc.org/38-general-linuxc...-do-i-update-to-2-10 - and having the first two things fail with - www.linuxcnc.org bookworm InRelease' doesn't have the component 'master-uspace - I do not dare go any further as I do not want to risk what is working now. It took weeks to get the machine running and I do not want to have to start from scratch again. For now, I can at least set my tool height each time I change a tool by use a shim on the work piece top. A bit of a PTA but better than nothing.
- COFHAL
- Thank you received: 62
02 May 2026 01:37 #346092
by COFHAL
Replied by COFHAL on topic QTDragon_hd with mechanical dial tool setter
I have a silly question: how do I install this version to replace the original one that comes with LCN?
- persei8
10 Jun 2026 16:30 #347021
by persei8
Time to create page: 0.131 seconds
