QtDragon Customize
- amir73
31 May 2025 13:24 - 31 May 2025 13:29 #329446
by amir73
QtDragon Customize was created by amir73
I'm trying to customize the QtDragon screen. I'm copying using qtvcp copy. but when I start I get an error. The screen copy is called inova. With QtAxis everything is fine.
Last edit: 31 May 2025 13:29 by Lcvette. Reason: moving to qtvcp
- Thank you received: 2173
31 May 2025 19:14 #329464
Replied by cmorley on topic QtDragon Customize
Either change all the HAL pin names in the Hal files from qtdragon to inova or add -c qtdragon to the load line in the INI.
DISPLAY = qtvcp -d -c qtdragon inova
The following user(s) said Thank You: amir73
- amir73
01 Jun 2025 03:43 #329491
by amir73
Replied by amir73 on topic QtDragon Customize
nice....thanks
Time to create page: 0.195 seconds
