installing QTVCP
12 Oct 2025 08:02 #336322 by Twitchy88
installing QTVCP was created by Twitchy88
i followed the pinned post here for installing and i get this:
nate@linuxcnc-laptop:~$ desginer -qt=5
bash: desginer: command not found
12 Oct 2025 10:14 #336329 by Twitchy88
Replied by Twitchy88 on topic installing QTVCP
Yep, i think i typed that out fast for the forum, also the laptop will just be for learning when I cant make it out to the shop.
Selection? 3
installing common tools
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Package qttools5-dev-tools is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Unable to locate package qttools5-dev
E: Package 'qttools5-dev-tools' has no installation candidate
installing python3 tools
E: Unable to locate package libpython3-dev
create plugin link at:
~/.designer/plugins/python/
Installation complete, designer can be started with:
designer -qt=5
nate@linuxcnc-laptop:~$ designer -qt=5
bash: designer: command not found
12 Oct 2025 11:43 #336334 by andypugh
Replied by andypugh on topic installing QTVCP
There are two packages not being found or downloaded. (qttools5-dev,
libpython3-dev)
We (well, mainly you :-) need to work out why that is.
You could try updating the apt archive
sudo apt-get update
And then see if you can find them, for example:
sudo apt-cache search qttools
12 Oct 2025 22:14 #336359 by cmorley
Replied by cmorley on topic installing QTVCP
What version of linux are you using?
Time to create page: 0.284 seconds
