I’m setting up automatic tool measurement on a 6-axis CNC mill using QtDragon with VersaProbe and running into calculation errors. The M6 remap executes successfully but produces incorrect/inconsistent tool offsets.
Machine Configuration:
• LinuxCNC 2.9.7
• GUI: QtDragon 1.4
• Interface: Mesa 7i96s Ethernet
• Axes: 6-axis (dual X gantry: X1, X2, Y, Z, A, B rotary)
• Tool change: Manual (no ATC)
• Fixed tool setter at machine coordinates X=397, Y=680, Z=-100mm
• Touch plate height: 41.54mm
• Actual physical tool length difference: ~22mm
What Works:
✓ M6 remap executes without hanging
✓ Machine moves to tool setter position correctly
✓ Probe successfully touches tool setter
✓ Returns to safe position
✓ tool-prepare-loopback HAL connection working
The Problem:
Tool offsets in the tool table are completely wrong and inconsistent:
Test Run 1:
• Tool 1: -29.113mm
• Tool 2: -7.077mm
• Difference: 22mm ✓ (correct!)
Test Run 2 (same tools, same setup):
• Tool 1: 0.070mm
• Tool 2: -22.105mm
The relative difference is consistently correct (22mm), but the absolute values shift by 30-50mm between runs. Sometimes offsets are even positive when they should be negative.
My Workflow:
1. Home all axes
2. Clear all tool offsets (set Z to 0.0)
3. Jog tool to table surface, run G10 L20 P1 Z0 (set G54 Z=0)
4. Run T1 M6 - measures Tool 1
5. Run T2 M6 - measures Tool 2
6. Check tool table - offsets are wrongQuestions:
1. Should I be using G10 L1 (absolute) or G10 L10 (relative) for tool offset?
2. Is capturing #5420 before switching to G91 the correct way to get machine Z position?
3. After probing in G91 mode, is #5063 the incremental distance traveled, or does it contain machine coordinates?
4. Should the calculation be:
• probe_machine_z - probe_height (current), or
• tool_setter_Z - probe_machine_z + probe_height, or
• Something else entirely?
1. I’ve read that some people use Tool 99 as a reference probe - is that required, or should direct tool measurement work?
Related threads I’ve studied:
• forum.linuxcnc.org/40-subroutines-and-ngcgui/52490-remap-m6-tool-setter
• forum.linuxcnc.org/qtvcp/51138-qtdragonhd-tool-sensor-help-for-a-maker-space
Any help would be greatly appreciated! I can provide additional config files or testing results if needed.
5_axis.ini (VersaProbe section):
[VERSA_TOOLSETTER]
X = 397.000
Y = 680.000
Z = -100
Z_MAX_CLEAR = -50
MAXPROBE = 80
custom_postgui.hal:
net probe-in => qtdragon.led-probe
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
net tool-prep-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number
qt_auto_probe_tool.ngc (key sections):
# Line 54: Clear offset before measurement
G10 L1 P#<tool> Z0
# Lines 56-57: Move to tool setter
G53 G0 X[#<_ini[VERSA_TOOLSETTER]X>] Y[#<_ini[VERSA_TOOLSETTER]Y>]
G53 G0 Z[#<_ini[VERSA_TOOLSETTER]Z>]
# Line 61: Capture starting Z (attempted fix)
#<start_machine_z> = #5420
# Line 63: Switch to incremental mode
G91
# Lines 64-71: First probe (fast)
G38.3 Z- #<_ini[VERSA_TOOLSETTER]MAXPROBE>
G0 Z #<_hal[qtversaprobe.backoffdist]>
# Lines 75-78: Second probe (slow)
G38.3 Z- [#<_hal[qtversaprobe.backoffdist]> *1.2]
# Lines 79-80: Calculate machine Z position
#<probe_distance> = #5063
#<probe_machine_z> = [#<start_machine_z> + #<probe_distance>]
# Line 82: Return to absolute mode
G90
# Line 88: Set tool offset (THIS IS WHERE THE PROBLEM IS)
G10 L1 P#<tool> Z[#<probe_machine_z> - #<_hal[qtversaprobe.probeheight]> + #<_hal[qtversaprobe.blockheight]>]
