Gui message while homing with shared home/limit swiches
  • tuxcnc
  • Elite Member
  • Elite Member
11 Aug 2026 22:27 #348662 by tuxcnc
I can't help you.
I gave you working example.
You only have to remove from your config unnecessary stuff and replace parport pin by mesa pin.
But you see only that is one line not many...
12 Aug 2026 12:21 #348669 by rubes
thanx, but I already had a working solution to my "problem" so didnt actually need your help by that time. I guess i am obviously an idiot because i didn't fall all over myself thanking you, and using your solution rather than the one i worked hard at figuring out while not knowing anything about HAL or Linuxcnc.
12 Aug 2026 13:28 - 12 Aug 2026 13:33 #348670 by Aciera
I think this is actually a bug in the QtDragon GUI.
Moved to the Qtvcp section so maybe @cmorley picks it up.
Last edit: 12 Aug 2026 13:33 by Aciera.
12 Aug 2026 14:22 #348671 by PCW
That seems likely since there must be 1000's of LinuxCNC installations using
shared home/limits and this is the first time I've seen this complaint.
12 Aug 2026 18:46 #348674 by rubes
just FYI, I moved this configuration off the RPI-4 onto a new computer (fresh installation from the released ISO) and still get the same. Figures I would be the only one to have this "issue". Am I the only one using QtDragon? cant be, as it is a very cool GUI.
  • tuxcnc
  • Elite Member
  • Elite Member
12 Aug 2026 22:37 #348684 by tuxcnc
No. You are only one using your config.
13 Aug 2026 07:29 #348696 by rodw
If it is, its a new one, I had no problems with a single home/limit switcch. Feel free to review my hal and ini files
github.com/rodw-au/vmnmillqt/tree/main
13 Aug 2026 08:04 #348698 by cmorley
It's more likely the bogus message comes from hal_glib library watching the limits switches without knowing about shared homing use.
