LinuxCnc logo
4 years 5 months ago #242583 by Muecke
Replied by Muecke on topic LinuxCnc logo
-- de --
der Bohrer sieht sehr gut aus!
Wenn ich das Bild verkleinere sind die Konturen vom Bohrer nicht mehr so gut zu erkennen.
Auf dem Alten Bild hat man das besser erkannt.
-- en --
the drill looks very good!
If I reduce the image, the contours of the drill are no longer so well visible.
On the old picture you can see it better.
4 years 5 months ago #242587 by XXCoder
Replied by XXCoder on topic LinuxCnc logo
Ok I will play with stronger color gradients later
4 years 5 months ago #242595 by silopolis
Replied by silopolis on topic LinuxCnc logo
Indeed outline of the mill could be a little stronger... And IMHO, the ones of chips a little less :)
Also, the glasses leg could be a little thinner.
Posted a message in #linuxcnc-devel to ask devs what think about adding it to source tree...
About location in tree, logos are at repository root ATM, so make a PR there if you want to.
4 years 5 months ago #242729 by XXCoder
OKAY! I have taken in suggestions, and found original SVG! I was still meh on original, since while it is certainly better than remake I have been using, it still had problems.
So I decided to make sort of hybrid of both. Chip is slightly darker for contrast, Chip has more modern goggles. I have reshaped some of body and beak for better look.
The endmill now is lighter, and have strong black borders!
image missing https://media.discordapp.net/attachments/970073318810075149/974170692864065606/unknown.png
Left is old Chips, right is recreation. Middle is brand new one. As you can see, it is mostly same as left original.
image missing https://media.discordapp.net/attachments/970073318810075149/974176968746631168/g2923.png
Mascot with endmill.
The following user(s) said Thank You: Bari
4 years 5 months ago #242730 by XXCoder
image missing https://media.discordapp.net/attachments/970073318810075149/974174803256815716/unknown.png
What it looks like when it is tiny
4 years 5 months ago #242731 by rodw
Replied by rodw on topic LinuxCnc logo
Is there any reason why these can't be pushed to github master branch in Git?
Time to create page: 0.937 seconds
