Hardinge HC Lathe - CNC Conversion
7 years 5 months ago - 7 years 5 months ago #134343 by Skippy1
Guys,
After some more delays, I managed to finish a Mesa 7i73 based control panel for the lathe today. The top three knobs allow manual selection of axis and increments, and jogging movements via the manual pulse generator. Two of the bottom knobs are Grayhill optical encoder/switches, which allow changes to spindle speed and feed rates while a program is running, to fine tune machining operations. Two knobs are also push switches, which allow start, pause, step, and resume of programs using, someone else's code
As always, thanks to the guys on the forum for advice on getting it working. :)
Last edit: 7 years 5 months ago by Skippy1. Reason: Grammer, always grammer.
7 years 5 months ago #134651 by tommylight
7 years 5 months ago #134690 by RotarySMP
Nice workmanship. Would be cool if you could post a Youtube video of it in action.
7 years 5 months ago #134695 by OT-CNC
Nice work and cool looking controller. How is it mounted? Is it on an arm? I did mine on my AHC so it can swing out of the way mounted on the right side. I still feel like having to wear a rain coat every time I use coolant as it gets all over the place. Will you be adding some kind of chip shield?
7 years 5 months ago #134747 by Skippy1
Thanks guys,
The panel has a bracket on the back, with a 3/4" pin which drops into a hole in the headstock, where the original Hardinge motor speed controller fitted. It can swivel, but not move.
I was considering mounting a removable sheet of 3/8" polycarbonate against the headstock, with a 6" hole to fit over the spindle bearing retaining/labyrinth seal ring. The perspective of the photo is a bit out, but the right hand side of the panel would be behind and protected by the poly sheet.
I'm a bit of a technophobe, and YouTube is a bridge too far for me. If I get my finger out one day, I may get something up, but don't hold your breath.
Cheers, Steve
7 years 3 months ago #140082 by Dinuka_Shehan
Nice work!
Neat and tidy too.
cheers:)
Time to create page: 0.336 seconds
