Another cnc plasma cutter, two floating heads, with 3.5X2M work area or 12X7'
  • Topic Author
  • Moderator
  • Moderator
8 years 3 weeks ago #118521 by tommylight
Nearly finished , needs some magnetic holders for the torches, a monitor stand and something to bolt the electronics box to, going to be used with a plasma torch and an acetylene torch, can be used with two plasma torches as it has probe sensors and home switches on both Z axis.
Uses belts on X and double Y axis, NOOK ball screws on both Z axis, HiWin rails on Y axis, precision guides on the X axis (the long axis or gantry), and dual double drawer slides with ball bearings on Z axis ( yes two of the dual slides, will do some pictures of it ).
More videos when it is finished.
Regards,
Tom
The following user(s) said Thank You: Plasmaguy
Time to create page: 0.037 seconds
