tommylight wrote: ... That seems all good, and with that reduction it will be also usable as a router for sure. I did try to surf the gantry yesterday at 10m/m for over 10 minutes i was jumping on it, and they never stalled.
That is with Nema 23 motors at 1.8A, 1:3 reduction and a 15 tooth 3mm pitch pulley, so 15mm per revolution of the motor, or ideal for plasma cutting.
Hi - been reading through this thread and others very closely as I get my head around what seems to be working and not working etc.
I "think" I know what I should be getting but I got a little confused in the series of exchanges and the numbers being used. If possible a clarification would be very helpful.
Context: looking at a "small" table with a cut area of circa 1200x600mm with gantry and Z assemblies constructed from Aluminium for minium weight. Only the base table and water try are going to be steel. Even the water tray may be ali sheet with the replaceable steel support ribbing. This is based on available space and a desire to be able to handle (in segments) the standard metric sized sheeting typically found in my area.
This is a hobby/learning/fun build. If it becomes more only time will tell.
Questions:
For this size table I THINK Nema 23 motors with 3:1 gearing from the motor (i.e. motor turns 3 times for 1 turn of the pulley on the belt) should be ok. But people talk different amperage sizes and sometimes that seems to be getting mixed up with the Holding torque?
For example I am looking at a set of motors that are spec'd as:
Current:3.0A
Resistence:1.1Ω
Inductance:3.6mH
Holding Torque:1.89Nm
Weight: 1.2Kg
Yet there is mention of 1.8A or 2A motors? I am not seeing anything like that about. Was that really 1.8Nm or 2Nm torque mottors? Or am I missing something?
Or would a motor set looking like below be preferable?
Current:3.0A
Resistence:0.9Ω
Inductance:2.4mH
Holding Torque:1.26Nm
Weight: 0.72Kg
PSU feeding either set would be 36V with DM542 digitial drivers.
Really appreciate any clarification or advice.
Thanks,
James.
