Plasma Linuxcnc finally running correctly
- jay1st
- Thank you received: 17
20 May 2020 02:26 - 20 May 2020 02:36 #168347
by jay1st
Plasma Linuxcnc finally running correctly was created by jay1st
Finally i got it to run smoothly and correctly.
Solved my THC problems using a cheap pilot arc HF plasma cutter
Now i need to save some money to buy a serious plasma genrator!
Last edit: 20 May 2020 02:36 by jay1st.
The following user(s) said Thank You: phillc54, tommylight, rodw
- Thank you received: 7504
20 May 2020 17:58 #168415
Replied by tommylight on topic Plasma Linuxcnc finally running correctly
Nice to see it working properly.
Regards,
Tom.
P.S.
just noticed a typo on the subject, try to edit it and if it does not stick let me know, i will make it stick.
Regards,
Tom.
P.S.
The following user(s) said Thank You: jay1st
- jay1st
22 May 2020 02:49 #168560
by jay1st
Replied by jay1st on topic Plasma Linuxcnc finally running correctly
i cant change it
and the other topic as well, as it's more " how to make a pilot arc torch work with a THCAD"
22 May 2020 04:20 #168563
Let's see if it sticks!
The subject, that is.
- Thank you received: 4154
22 May 2020 04:51 #168567
Replied by rodw on topic Plasma Linuxcnc finally running correctly
Finally correct(ly)! I have found you need to edit the first post and then edit the last post to change it.
- jay1st
22 May 2020 10:40 #168584
by jay1st
good to know !
Time to create page: 0.439 seconds
