LinuxCNC for SLS Printiers
- Bari
- Thank you received: 234
30 May 2020 20:57 - 30 May 2020 21:22 #169469
by Bari
LinuxCNC for SLS Printiers was created by Bari
Just so people know imgur.com/LxSPzg7
LinuxCNC may easily be used to control a SLS printer. The powder bed and spreader is not shown in the video. A piece of lumber is used for demonstration of the controlled laser path.
This printer uses a analog +/- 5V galvo and 20W CO2 RF laser.
A Mesa 7i77 is used in open loop mode to control the analog galvos.
There is a new XY2-100 digital interface that also works with LinuxCNC for use with digital galvo heads.
www.linuxcnc.org/docs/html/drivers/hostmot2.html
Last edit: 30 May 2020 21:22 by Bari. Reason: typo
The following user(s) said Thank You: tommylight, Aciera, bbsr_5a
- bbsr_5a
- Thank you received: 106
01 Jun 2020 03:14 #169627
by bbsr_5a
Replied by bbsr_5a on topic LinuxCNC for SLS Printiers
what is the optic precision beam diameter min-max to melt sinter of the system used
- Bari
01 Jun 2020 10:57 #169683
by Bari
Replied by Bari on topic LinuxCNC for SLS Printiers
Doesn't matter much to LCNC. All of that is dependent on the beam source, beam expander, galvos and lens or fiber laser used.
Time to create page: 0.618 seconds
