another configed Cnc plasma from tommylight
- shpatb
- Thank you received: 62
04 Oct 2020 18:40 #184863
by shpatb
another configed Cnc plasma from tommylight was created by shpatb
Build this machine a year ago , as it originally had mach 3 as a controller.
Due to HF it was almost unusable because it would make unaccurate cuts after some mins of it working , had tommy come by and fix it, ,looked better on first tests.
Its a wonderful thing back to sit back and see tommy work as a machine, He literally worked 9h nonstop as he refused to eat while he was working ..
Need 1-2 more days to deal with software as i have no experience on linux and inskape for drawing stuff...then i'll put it to rigid testing to see if HF is still causing accuracy cutting..
thanks tommy for coming by and making this community a wonderful place to learn from each other :DD
here is a video of me messing with the machine.:
will post more when its ready for cutting.
all the best, Shpat!
- Thank you received: 7478
04 Oct 2020 21:43 #184875
Replied by tommylight on topic another configed Cnc plasma from tommylight
Woke up at 8AM, went there to work, had breakfast at 10:25PM !
Work is work.
Thank you for the kind words.
Work is work.
The following user(s) said Thank You: shpatb
- phillc54
- Thank you received: 2100
05 Oct 2020 00:27 #184890
by phillc54
Was that breakfast in the first few frames?
Replied by phillc54 on topic another configed Cnc plasma from tommylight
Great work Tom.Woke up at 8AM, went there to work, had breakfast at 10:25PM !
Work is work.
05 Oct 2020 07:47 #184940
Yes, but not mine !
Time to create page: 1.043 seconds
