Okuma Ramcon 3 Ram type mill retrofit - Linux newbie
  • harindugamlath
  • Topic Author
  • Senior Member
  • Senior Member
5 years 11 months ago #189126 by harindugamlath
Hi Guys,
I have gained a lot of knowledge from this forum and I think it's time to give some back for folks like me who dive deep in to the rabbit hole without knowing anything and hoping for light on the other side. Trust me this was one of the hardest projects I ever did. Still not finished in any way but I think now I have a solid base to start with and properly ask some questions on Linuxcnc and Probe basic gui.
Firstly thanks to all who contributed to linuxcnc and all to answer my stupid questions.:silly:
So, This what I did with my mill retrofit.
About an year ago I found this Old Okuma Howa ram type mill on a yard full of old japanese industrial equipment.
image missing https://i.imgur.com/j0MBOUZ.jpg
I live in Sri Lanka (Tiny island nation) and usually old japanese industrial equipment end up here and this is what everyone uses. they rarely import brand new machines and the old stuff sell for top price (sadly but true).
image missing https://i.imgur.com/exAyikp.jpg
image missing https://i.imgur.com/4mgrCuB.jpg
  • harindugamlath
  • Topic Author
  • Senior Member
  • Senior Member
5 years 11 months ago #189127 by harindugamlath
Replied by harindugamlath on topic Okuma Ramcon 3 Ram type mill retrofit - Linux newbie
Y axis (the Ram hence the name Ramcon I guess)
image missing https://i.imgur.com/NXXmUwD.jpg
image missing https://i.imgur.com/XRLoMeP.jpg
image missing https://i.imgur.com/nsUAb7n.jpg
image missing https://i.imgur.com/JJbZXHS.jpg
The guy was asking about $2000 for this one and it turned out he had this machine for some time and was unable to sell it. Simply because it was an NC Mill(Not fully CNC) and had no hand wheels or any other manual control. Everything worked through the basic NC control system and the whole cabinet for the control system was missing. :( Somewhere down the line from japan to sri lanka someone probably stole the cabit for the fanuc drives? Don't really know but this thing had some really large size DC servos.
  • harindugamlath
  • Topic Author
  • Senior Member
  • Senior Member
5 years 11 months ago #189128 by harindugamlath
This is the cabinet with power distribution with relays and contactors.
image missing https://i.imgur.com/bF0fYE6.jpg
Price was cheap for something like this around here (usually a decent bridgeport sells for the same) So I ended up buying it.
image missing https://i.imgur.com/951SMhO.jpg
Finally at my small workshop with the old 6090 router.
image missing https://i.imgur.com/vAbVXHi.jpg
image missing https://i.imgur.com/yX5sC99.jpg
Had to call a guy with moving pads as this weighed some where at 4.5 ton.
  • harindugamlath
  • Topic Author
  • Senior Member
  • Senior Member
5 years 11 months ago #189129 by harindugamlath
This thing had the biggest servo I have seen on a mill of this size. (Gettys Fanuc Model 20. 128V 33A)
image missing https://i.imgur.com/q2BXPrU.jpg
image missing https://i.imgur.com/6PUYjm4.jpg
Turned out it was almost shot (recused it though. More on that later)
  • harindugamlath
  • Topic Author
  • Senior Member
  • Senior Member
5 years 11 months ago #189130 by harindugamlath
So a bit of info on the mill.
This has some good travel lengths (850mm on X , 500mm on Y and 420mm on Z) and super beefy box ways on all axis and two large pneumatic cylinders to support the z axis. There is an adjustable quill but its not really possible to drill with it.
Here is what confused me. This thing has ground (and very accurate) 40mm preloaded double nut ball screws and they are coupled through gear boxes ? :S :blink:
image missing https://i.imgur.com/fVRRLZx.jpg
image missing https://i.imgur.com/GFaUdfQ.jpg
image missing https://i.imgur.com/cn1ste5.jpg
image missing https://i.imgur.com/YGgtkJ6.jpg
and those gear ratios turned out to be 1:1 also. (There is an pinion wheel on the Z screw which is 1:4 but the Z motor had another 1:1 wheel set coupled just like the above photos X & Y )
So this thing had heaps of backlash. I mean a lot. The good thing with DC servos is you can just run them with a battery. Ryobi 2.5Ah pack was able to move all the axis. i was not worn or anything but the straight cut gears had some considerable clearance (or play).
These were the x and y axis motors. (Gettys Fanus Model 20 on Z)
image missing https://i.imgur.com/5Fb0RsN.jpg
  • harindugamlath
  • Topic Author
  • Senior Member
  • Senior Member
5 years 11 months ago #189134 by harindugamlath
I typed all in one but the it didn't allow me to post all in one post. So had to break them up.
I'll show what I did and how I converted the gearboxes tomorrow. the mill turned out to be really accurate (actually more that I expected at first. I'll do my best to share)
Thanks everyone.
The following user(s) said Thank You: Mike_Eitel, tommylight, Clive S
5 years 11 months ago #189196 by johnmc1
Thanks for the photos ,
The gears on the dc motors are hardened and ground, also some had a eccentric ring on the mounting flange, that allowed for a adjustment to remove the backlash.
The motors look like they have pulse encoders but no tachometers.
cheers john
5 years 11 months ago #190679 by versal_arslan
Please inform me the exact net weight of machine i have same machine and i want to scrap it.
5 years 11 months ago - 5 years 11 months ago #190680 by versal_arslan
You mentioned above it have arround 4.5 ton. Net weight Is it right???
Last edit: 5 years 11 months ago by versal_arslan.
Time to create page: 0.961 seconds
