Barnworks shop update
5 years 1 day ago #224754 by anfänger
Replied by anfänger on topic Barnworks shop update
Yea the machine is from 86, and has an analog DC servo control with gals scales as feedback. And was build as a CNC.
Iv‘e already converted a 89 cnc machine to linuxcnc keeping servo an sprinkle drive. As long as they are running I don‘t see any reason to change them. Especially when they are well documented like Sinumerik or Heidenhein. And when they fail and I can‘t repair, they will be replaced with something modern.
I just think it would be fun to get her running as she is to play a bit around. After all there is no real need for this machine yet. I bought it for the fun of it. And she is a really nice addition to have fun with in the shop.
4 years 11 months ago #225440 by my1987toyota
Replied by my1987toyota on topic Barnworks shop update
  It's nice when you can keep old iron operating. It's even better when you can improve it with modern electronics.
I hope the project goes well.
4 years 11 months ago #225516 by anfänger
Started to look a the Fehlmann, First she got new batteries and her won socket (no more extension cords lying around and I really appreciate the cable channels, they were a good decision)
[img
[img
the I reset the parameters but still got an error message:
[img
this kind of points towards E-Stop or Power Supply. So I checked the E-Stop and found an open connection, but it sill didn't start.
So I took the multimeters and found all Inputs are low, wich is kind of odd. Also the LED's of some of the thingies in the cabinet look darker than others.
[img
I DIsconnected two signals the should habe been high from the Circus board and the they were high.
So my guess at the moment is the 24 / 12 / 6V Powersupply or this circuit board:
[img
Tomorrow I will have a look at the powers supply but also started an IO List and cam to the conclusion I would need an 7I97 and 7IA0 (hope this card is supported) to get enough IO's and I would be able to add Glas scales to the column later.
I would like to keep the key pads but they have a bit logic. You get an button pressed signal and 5 Inputs are used to make a pattern, the led's can get and feedback on the same way. I wonder if this would be possible to get this running. The I Can also keep the hand device cause this works the same way.
4 years 11 months ago #225534 by anfänger
Most of the buttons are used in manual mode, so it can be handled in user space I guess. So writing a python component should be an easy solution.
[img
The backlight, loadmeter and segment display can also be done in userspace
[img
4 years 11 months ago #225556 by db1981
Replied by db1981 on topic Barnworks shop update
Hi ,
Tnc 355
You have to press the ce Button at the num Block After power on .
To Enable for switching estop on .
4 years 11 months ago #225558 by anfänger
Hi,  It's a TNC 155 and I've already tried that.
I thought it was the power supply an I found the the second 24V section dead, so I used another power supply to feed 24V to the machine. And also fed the power good and E-stop directly from the power supply.
[img
I checked all the contactors if they were working and they did.
[img
But nothing really changed except the drives now get power. I tried to read the status f the it's in the control but the control doesn't react to anything. Not even trying ti change parameters.
[img
I guess I will get new power supplies.
12 V and 6 V I can skip, cause they are for a lamp and the optics, which I won't use or have.
I need to find out what is using 24V AC maybe I can remove / replace that too.
And I will need to get the Mesa boards and a 5V power supply.
So be prepares for a retrofit thread coming soon, where I will as a lot of strange questions like:
how mad is the idea to use python and 6 O's from the mesa board to send data to the control panel:
[img
my guess is they use the rising flank to trigger the read of the four data bits, so speed isn't crucial.
Or can I use two joints overlaying each other where one is the column wich can't be PID controlled and has a simple single speed up and down.
Bit ist be able to get its position from a glas scale. Z improve the Z Axis So don't need to reset the WCS when I move the column.
Time to create page: 2.556 seconds
