Promecor Lathe retrofit with TKXHMI
06 May 2022 23:42 #242183 by fsabbatini
Promecor Lathe retrofit with TKXHMI was created by fsabbatini
Just las lathe retrofit I did!
  • Moderator
  • Moderator
06 May 2022 23:48 #242184 by tommylight
Replied by tommylight on topic Promecor Lathe retrofit with TKXHMI
Where? How? What?
06 May 2022 23:50 #242185 by fsabbatini
Replied by fsabbatini on topic Promecor Lathe retrofit with TKXHMI
Hahaha I guess the link didn’t went through, here it goes again
  • Moderator
  • Moderator
06 May 2022 23:56 #242186 by tommylight
Very nice, thank you.
Video 2 not working for me.
09 May 2022 04:42 #242351 by Becksvill
Replied by Becksvill on topic Promecor Lathe retrofit with TKXHMI
Love it!
What framework are you using?
And have you got tool wear offsets working well?
Regards
Andrew
09 May 2022 06:22 #242359 by silopolis
Replied by silopolis on topic Promecor Lathe retrofit with TKXHMI
Hey !
Very happy to see this post (thanks Andrew for pointing us there on the mailing list :+1: ) !
You know from YT comments that at least Phil and I are big fans of $inumerik UI and features, so you won't be surprised we hope to know anything and everything of this gorgeous implementation :)
Congratulations anyway for this and thanks for showcasing this build.
TY
10 May 2022 13:22 #242488 by tome
Replied by tome on topic Promecor Lathe retrofit with TKXHMI
Hey !
TY
Add me to that list! Is this user interface available?  Also, what is the interface hardware, that doesn’t look original to the machine?
-Tom
  • Moderator
  • Moderator
10 May 2022 16:57 #242504 by tommylight
Title fixed from "larhe" to "lathe".
15 May 2022 18:57 #243040 by fsabbatini
Thanks all for your replies!
I have been working for about one and a half years on this. Some history first:
We are a company localized in Argentina, we have been building special machines for several industria for 25 years and always using Fanuc/Siemens on our machines. This country government has many restrictions on imported goods (because lack of dollars, populism and issues we can argue all day long) so I started working on making Linuxcnc more professional , and what I got so far is this:
-proper single block working
-industrial tool manager with life manager by part count or by cutting time. Tools offsets and tool wears. Tool manager working as $inumerik , meaning you can have t3d1 for example and also t3d2 , you can have as many edges for a tool as you want.
-kind or R parameters (using variables) but showed on the screen.
-MDI working as $inumerik or Fanuc, you can put several commands in same file
-currently executing line showing exactly as it should be! Even in subroutines (for gosh sake!!!)
-interface for touch screen, mouse not required any more
-editor able to open file while machine working
-several editors opening at same time
-usb handled right on the hmi, no need to go to desktop to copy files
-PLC alarms bits (%Axx) to show alarms at hmi, distinguishes between messages and alarms
-offsets now have “fine” correction
-(POPUP, “example”) shows popup on hmi for operator information
-ethercat drive homing implemented into homing.c
-m66 can wait forever
-m functions gives output to PLC (if configured) and plc must acknowledge it
And many more I am not remembering right now.. if you like I can post more videos of all these features
Sorry my misstyping , doing this from the phone!
Regards
Franco!
The following user(s) said Thank You: PKM, tommylight, HalaszAttila, spumco
15 May 2022 19:18 #243043 by cmorley
Replied by cmorley on topic Promecor Lathe retrofit with TKXHMI
Will you release the code changes to linuxcnc?
Time to create page: 0.126 seconds
