- Thank you received: 426
Yeah, problem there is you can only access a serial port from userspace otherwise it would be good. USB you would probably have to throw out the window, but if someone wrote an actual real-time serial port driver it'd probably be great.Good that you mention Python. A couple weeks ago I learned how to build custom .comp components and I was thinking about moving the communication and logic Part into one.
But I am not sure how much this would improve anything. I guess the Bottleneck is the USB Serial anyway? What do you guys think?
Yeah, you could use those cards for whatever you want but there's no analog IO on the 7i90/7i92 so you can't really call it a control panel card unless it can do a basic potentiometer reading.Just a note, the 7i90, FPGA (not having a go but there is always some that breaks the rules) can be used as smart serial device. Just digital i/o and 3 mpgs, but the firmware that runs on the softcore can be modded for 4
Mpgs. Tho it was a little frustrating to do at first.
I like the I2C IO expansion Idea. I don't have these chips here yet. As I am working on the next Version of Arduino Connector I would implement it in the newer version as it will improve on all the Issues learned from the current version, as it will also get rid of the #defines etc for the user.I'll probably fork your repo and push my changes for the I2C IO expanders if you want to take a look at that. Could use some work around the ifdef's for enabling the I2C IO aside from the normal Arduino IO but on my Mega setup it's working great.
Yeah I've seen the v2 but never tried it because it's mentioned in the repo that it doesn't currently work.I like the I2C IO expansion Idea. I don't have these chips here yet. As I am working on the next Version of Arduino Connector I would implement it in the newer version as it will improve on all the Issues learned from the current version, as it will also get rid of the #defines etc for the user.
Also I forgot to mention that the new Version already supports the connection to multiple Arduinos simultaneously.
If you would like to peek into it you can see it on Github in the dev branch, but keep in mind currently it doesn't work.
Here is a preview of how the new Yaml configuration looks like: github.com/AlexmagToast/LinuxCNC_Arduino...lob/dev/config2.yaml
