Arduino IO Expansion
19 Jan 2025 06:23 - 19 Jan 2025 06:28 #319348 by blazini36
Replied by blazini36 on topic Arduino IO Expansion
Nice setup old chap, puts my merger efforts at PCB design to shame.
I remember there was a thread about the BSPI thing, tried searching but couldn't find it.
Yeah I make plenty of PCBs, I tend to make one or two revisions, get everything working, and then stuff it on the shelf because I stop working on whatever it was mean for.
That one was for a pick and place machine I made that I wanted to get working with OpenPnP on top of LinuxCNC. I did get it moving around but I was having too much trouble getting both OpenPnP and LinuxCNC to play nice......so on the shelf it went. I don't really have the attention span to try to get LinuxCNC fully integrated for a PnP by itself but I'm sure it can be done, the guy who does the Mitsubishi servo cards managed to do it.
These break out boards intended for Arduino Connector have probably been sitting around for like a year now. Had to bodge out a couple of mistakes on both the Mega and Teensy 4.1 versions but it'll be good enough to get my control panel finally working. Then I'll go back and make a (hopefully) final revision.
Last edit: 19 Jan 2025 06:28 by blazini36.
  • Platinum Member
  • Platinum Member
19 Jan 2025 09:31 #319353 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Arduino IO Expansion
As much as we had a difference of opinion our work flow seems to be on similar lines.
Now that the RPI5 has a driver suitable for the 7c81, it’s time to see if this BSPI thing works on the clone I put together.
I’ll use your thread as a reference, print out some of the man pages, 7i65 code, some data sheets and get the highlighters out. I guess a I’ll have to build the bit file as well.
  • AlexMagToast
  • AlexMagToast's Avatar Topic Author
  • Premium Member
  • Premium Member
19 Jan 2025 10:04 #319358 by AlexMagToast
Replied by AlexMagToast on topic Arduino IO Expansion
Right now I'm just looking at how Arduino-connector handles connection states. It seems that even the normal outputs don't reset when LinuxCNC is closed so things that were previously on (like LEDs) stay on. The same happens with the I2C outputs so I suppose it's expected.  Not sure if that's the intended behavior but I've trying to figure out how to reset all outputs (pull low) on disconnect. It's a bit hard to debug since there's only 1 serial connection referenced and it's taken over when LinuxCNC connects, but I have another serial port I can direct debug prints to.
Yes, I figure it is dangerous if the Arduino changes States by itself, at least if People decide to connect other things than LED Lights in Buttons to the Output pins. I implemented new settings in the new version that allows to define behaviour if the connection is lost.
Other than that it all seems to work pretty good, I found a blocking delay in the comalive function that was creating a bit of delay. I replaced that with a timer and it works much better. That plus the tweaks mentioned in the git issues, it's pretty responsive now.
Once I get done putzing around, I'll clean up my code a bit and upload it somewhere.
You can create a pull request if you want and I will merge it into the project.
19 Jan 2025 11:53 #319363 by blazini36
IIRC the problem with BSPI is that it was rarely ever used after it was written. I guess one lesser known Mesa card used it and I could only dig up a single ancient thread about it. I recall I was asking about it and toward the end of the thread it clicked in my head how the data packets work......then I shelved it. Maybe I'll get back to it one day.
12 Mar 2025 20:37 - 12 Mar 2025 20:38 #323774 by d12k6
Replied by d12k6 on topic Arduino IO Expansion
Hello, is it possible to create "internal buttons"? I mean not a physical button, but only in the software e.g.
if(value == x) internal_button = true
Last edit: 12 Mar 2025 20:38 by d12k6.
  • AlexMagToast
  • Premium Member
  • Premium Member
14 Mar 2025 18:09 #323948 by AlexMagToast
Sure, but can you please expain what you would like to do?
18 Mar 2025 16:18 #324213 by d12k6
e.g. touch tft or "waiting" for a analog value.
  • AlexMagToast
  • Premium Member
  • Premium Member
18 Mar 2025 21:30 #324232 by AlexMagToast
you mean if a analog value is above X = High, if below = LOW?
19 Mar 2025 06:21 #324264 by d12k6
exactly.
e.g. analog threshold:
if( value >= anaValue ) X = true
else X = false
or touch button:
if( isButtonPressed(btn, touchX, touchY )
X = true
else
X = false
22 Mar 2025 10:44 - 22 Mar 2025 10:48 #324533 by d12k6
I solved it (nicht das gelbe vom Ei but it works )
I call the sendData function
if (isButtonPressed(btnX, touchX, touchY))
btnX.state = !btnX.state;
drawButton(btnX);
sendData('I',8,btnX.state);
So I don't use physical buttons. Later I will share my TFT touch handweel (with your ArduinoConnector) on Github. I will modify your Code with virtual IO's and w/r strings (e.g. scale value - 0.01; 0.1; 1.0). Or, is there another why to send the scaling values to my linuxcnc?
Actully I manipulated the analog command in your python code (c["ain.{}".format(io)] = value/100 #remove /100 - now I send 1; 10; 100 for scaling) for the scaling function and will try it later with the r/w strings.
Last edit: 22 Mar 2025 10:48 by d12k6.
The following user(s) said Thank You: AlexMagToast
Time to create page: 0.274 seconds
