G68.x commands using euler angles will define both rotary axes in a single line because the new work plane can be completely defined by X,Y,Z offsets and the three euler angles I,J,K. If you want to define the work plane using 3 points or 2 vectors then you need more than one line of G68.2 Px Qx commands to enter all the parameters.Then, you would program a rotation of the second rotary axis using a second line of G68 code.
Note, G68.x codes do not use A,B or C words.G68 X Y Z A B C
TWP can be used in CAM/PP gcode generation as well as in manual programming on the controller.It was much less confusing to program the needed motion using a CAD/CAM system and not worry about the operator losing orientation.
You can rotate the head and then machine away like normal.
Sounds like LinuxCNC has some catching up to do if anyone wants to use those features.
