3W LED CNC Soldering Machine
  • ContinenteCNC
  • ContinenteCNC's Avatar Topic Author
  • Premium Member
  • Premium Member
10 Aug 2024 22:25 - 11 Aug 2024 00:45 #307443 by ContinenteCNC
3W LED CNC Soldering Machine was created by ContinenteCNC
This is my high power (3W) LED soldering machine. It holds the LED in place, displaces solder and heat the connection with a regular soldering iron.
It uses mostly ngcgui to handle the logic. It has some basic features like resoldering failed joints and a couple more.
It also displaces thermal greese with a interchangeble module. This video also shows how led's are placed in bulk.
It's unfortunate I can't open the source for this project because I did it for a company. But, anyway, it is quite simple to replicate. Nothing fancy. I hope it helps someone.
Last edit: 11 Aug 2024 00:45 by ContinenteCNC.
The following user(s) said Thank You: tommylight, pommen, COFHAL, djonz
10 Aug 2024 23:49 #307451 by tommylight
Replied by tommylight on topic A High Power LED Soldering Machine
Nicely done, maestro, thank you.
The following user(s) said Thank You: ContinenteCNC
Time to create page: 0.094 seconds
