Hydraulic Pipe Bender Retrofit - BLM C88
- ContinenteCNC
- Thank you received: 44
11 Aug 2024 17:58 - 13 Aug 2024 15:29 #307487
by ContinenteCNC
Hydraulic Pipe Bender Retrofit - BLM C88 was created by ContinenteCNC
This is a retrofit from a little while ago. It is a massive Italian pipe bender from the '80s.
In principle, it is a simple machine in terms of kinematics, but the size is intimidating. It had dozens of powerful hydraulic actuators and sensors, most of which would destroy themselves if actuated in the wrong sequence.
Two axes were driven by servo motors. We had to keep the old analog servo drivers, which was a requirement. They have resolvers and translators to encoder-like signals in each driver.
The 'bender' axis is hydraulic and uses a proportional valve for control. It is massive, and it’s hard to describe the sheer force this machine has—quite scary.
The kinematics were implemented in G-code, and the final result consists of several O-codes and routines working with custom HAL components to make everything function. In the end, it was about a second slower than the original one.
I had the opportunity to work with a great company that handled everything else. I just had to do the CNC work. It was a three-week job, working an average of 10-12 hours a day. It was worth it. The machine is working flawlessly.
This piece below is one of the most complicated ones in terms of logic. To avoid collisions, the machine has to release the pipe, bend it, hold it once again, and then push it to the last bend. The operator only has to input the dimensions, and the code is able to figure out on its own if there will be a collision and choose a way to avoid it.
This is the typical speed the machine runs
Last edit: 13 Aug 2024 15:29 by ContinenteCNC.
The following user(s) said Thank You: tommylight, pommen, besriworld, Aciera, Unlogic
- Tinine
- Thank you received: 12
23 Aug 2024 13:48 #308463
by Tinine
Replied by Tinine on topic Hydraulic Pipe Bender Retrofit - BLM C88
There is endless business to be had, retrofitting CNC tube benders and there are some very sophisticated ones. BLM, like other manufacturers, don't want to support older machines because they want people to buy new.
The "recapture" feature that you demonstrate is only one of many, many tricks that a CNC bender needs to be able to do.
These machines are my design/manufacture:
110mm Diameter...but two at the same time. This was the engine cradle for the Chrysler 300M. Bending axis is 100HP closed-loop Vector Drive
150mm with autoload Note: Every movement is a servo axis and coordinated
76mm 100% electric I was the pioneer of 100% electric and I was awarded the patent. Now BLM and everyone else makes all-electric benders
21 axis Fuel-injector lines for Ford and Siemens. The 8 rotating axes on the turret are WiFi controlled (continuous rotating turret.
I am now developing a self-install retrofit package which will be very low-cost....too many dead machines out there that are in fantastic mechanical condition.
Craig
Craig
- ContinenteCNC
19 Mar 2025 16:05 #324303
by ContinenteCNC
Replied by ContinenteCNC on topic Hydraulic Pipe Bender Retrofit - BLM C88
Hi Craig!
Those are insane machines! Great job!
Are them all controlled by LinuxCNC?
- Tinine
21 Mar 2025 13:49 - 21 Mar 2025 13:57 #324417
by Tinine
Hi Craig!
We created our own real-time system under Windows.
The axis interface was a PCI board with 12 DACs (16bit) and 24 quadrature encoder interfaces (we do dual-loop feedback) so this was PC-Based.
I have thousands of CNC tube-bender controls, worldwide.
Had enough of the PC and so now we switched to microcontrollers but with an Android-based HMI.
This year, I intend to introduce a TRUE open-source CNC metal forming control that utilizes ubiquitous hardware that anyone can obtain for pennies
All axes controlled by the RPi Pico. Any number of axes.
HMI can be any Android device such as phone, tablet, or panel-pc.
It's time that this stuff was simplified
Last edit: 21 Mar 2025 13:57 by Tinine.
- ContinenteCNC
21 Mar 2025 22:05 #324463
by ContinenteCNC
Wow!
Excellent news!
I am looking forward to check it out.
Excellent news!
Time to create page: 0.099 seconds
