Multi use FPGA Project
  • Topic Author
  • Platinum Member
  • Platinum Member
1 year 9 months ago #319175 by Cant do this anymore bye all
Multi use FPGA Project was created by Cant do this anymore bye all
github.com/ozzyrob/Linuxcnc-FPGA/tree/main
Spartan 6 based project.
Supports Linuxcnc-RIO either with direct spi connection or with the UDP Bridge.
Based on a common Spartan 6 dev board available via aliexpress.
Easily assembled, mostly through hole components only SMD parts are a couple of chips.
Modified 7c81 firmware spi mode
EPP interface also can be implemented.
Have experimented with firmware that supports upto 60 i/o (compared to 57 with the 7c81) requires a dedicated driver, easy enough to implement based on the 7i90 driver for EPP interface.
Easily interfaces to your basic Parallel Port breakout board, up to 3.
using a Aliexpress RS-422 interface baords allows SSerial connection, tested with a 7i73 device.
If anyone in Australia is interested I have a few unpopulated pcbs available.
The following user(s) said Thank You: besriworld, cakeslob
1 year 8 months ago #321699 by Aciera
Replied by Aciera on topic Multi use FPGA Project
Thanks for sharing.
Time to create page: 0.043 seconds
