HUGE Mazak fully automated 5 axis laser cutter for pipes/tubes/profiles/
1 year 3 months ago #332345 by andypugh
I am unclear. Does this cut laser tubes, or cut tubes using a laser?
Initially I assumed the former, but looking at it, I think it's the latter?
1 year 3 months ago #332349 by tommylight
It cuts metal pipes/tubes/profiles using a 4KW laser.
Sorry if i was unclear.
I will fix the tittle now, thank you for pointing it out.
1 year 2 months ago #333241 by tommylight
@ErrickW
Here is the exact controller model/type.
Thank you.
Now they have another issue that i think it is a safety feature, not an issue:
- when the left side is a straight cut, unloading works properly
- when there is any angle on the left side, even 4 degree tested, it will not unload, the left most spindle will not move at all
That is all the info i have so far, advised them to do a test cut where the angle is on the right side with the left side left straight, i have a feeling it will unload, but waiting till tomorrow for the result.
The following user(s) said Thank You: COFHAL
1 year 2 months ago #333969 by ErrickW
Tom, for some reason I never received your last post on 8/11/25. Contact me at 'linux at its-been-a-long dot com" I can help you with most any manual you need.
The following user(s) said Thank You: tommylight, besriworld
1 year 2 months ago #333984 by tommylight
Thank you Erick, i just talked to them and everything is OK, the left side angled not unloading is a safety feature as i thought, so the idea of leaving a straight cut in front of it with small tabs worked like a charm.
And we do have a pallet of manuals, mostly in Italian language and mostly not exactly for this machine as the pictures show the old version of the software, but still they did help a lot initially.
Again, thank you very much, i do appreciate the offer.
Time to create page: 0.322 seconds
