- Thank you received: 25
No, from 5000-9000 are subroutines.Any chance you used program numbers O9xxx or O8xxx .
Yes, of course.It should be in EDIT mode and EDIT key enabled.
Yes, i can choose any existing program, and no, this one runs everything from the first program in memory, as noted in the manual.Could you able to select different program to foreground or not? only the foreground program Number will run in Auto.
