- Other Stuff
- Show Your Stuff
- HUGE Mazak fully automated 5 axis laser cutter for pipes/tubes/profiles/
- ErrickW
- Thank you received: 8
25 Jul 2025 21:32 #332331
by ErrickW
Replied by ErrickW on topic HUGE Mazak fully automated 5 axis laser cutter for pipes/tubes/profiles/
Did you solve your problems with this machine?
- Thank you received: 7336
25 Jul 2025 22:39 #332333
Replied by tommylight on topic HUGE Mazak fully automated 5 axis laser cutter for pipes/tubes/profiles/
Yes, the networking part, we were misled badly and chased our tails by having the laptop wired to the console while the network required for file transfers was at the back of the main electronics cabinet! That is 6 hours i will never get back! I kept wondering why W2K has an IP set and the Mazak software has another IP set...now i know.
So now it can be used properly with the laptop, but i would still like to be able to use it without the laptop attached since i already figured out how to copy stuff to it, so i will report the exact model when they get back from Germany in a few days.
Thank you very much for everything.
- Thank you received: 4634
26 Jul 2025 00:25 #332345
Replied by andypugh on topic HUGE Mazak fully automated 5 axis laser cutter for pipes/tubes/profiles/
I am unclear. Does this cut laser tubes, or cut tubes using a laser?
Initially I assumed the former, but looking at it, I think it's the latter?
26 Jul 2025 01:40 #332349
It cuts metal pipes/tubes/profiles using a 4KW laser.
Sorry if i was unclear.
I will fix the tittle now, thank you for pointing it out.
11 Aug 2025 18:40 #333241
@ErrickW
Here is the exact controller model/type.
Thank you.
Now they have another issue that i think it is a safety feature, not an issue:
- when the left side is a straight cut, unloading works properly
- when there is any angle on the left side, even 4 degree tested, it will not unload, the left most spindle will not move at all
That is all the info i have so far, advised them to do a test cut where the angle is on the right side with the left side left straight, i have a feeling it will unload, but waiting till tomorrow for the result.
Thank you.
The following user(s) said Thank You: COFHAL
- ErrickW
26 Aug 2025 23:18 #333969
by ErrickW
Tom, for some reason I never received your last post on 8/11/25. Contact me at 'linux at its-been-a-long dot com" I can help you with most any manual you need.
The following user(s) said Thank You: tommylight, besriworld
27 Aug 2025 10:38 #333984
Thank you Erick, i just talked to them and everything is OK, the left side angled not unloading is a safety feature as i thought, so the idea of leaving a straight cut in front of it with small tabs worked like a charm.
And we do have a pallet of manuals, mostly in Italian language and mostly not exactly for this machine as the pictures show the old version of the software, but still they did help a lot initially.
Again, thank you very much, i do appreciate the offer.
- Other Stuff
- Show Your Stuff
Time to create page: 0.173 seconds
