MeasurefromSTL - Online measurement tool - Open source
- emresensoy
- Thank you received: 37
22 Aug 2026 13:57 #348922
by emresensoy
MeasurefromSTL - Online measurement tool - Open source was created by emresensoy
Shaft Gauge - a free browser tool to measure STL files (mm)
I built a small, single-file web tool for quickly reading dimensions off an STL mesh, handy when you just need a measurement without opening full CAD (with claude AI).
Drag in an STL and you get:
- Diameter and length (auto shaft-axis detection) plus full bounding-box dimensions
- Point-to-point distance with vertex snapping
- 3-point circle fit to read a bore/round feature diameter (works on tilted planes)
- 2D cross-sections on the XY / XZ / YZ planes with a movable slider
- Volume, triangle count, light/dark theme
No install, no sign-up, and your file never leaves your device - everything runs locally in the browser (binary and ASCII STL). Open source (MIT).
Live demo: emresensoy.github.io/MeasureFromSTL/
Source: github.com/emresensoy/MeasureFromSTL
Feedback and feature ideas welcome.
The following user(s) said Thank You: andypugh, COFHAL
- Online
- Thank you received: 7505
06 Sep 2026 19:00 #349406
Replied by tommylight on topic MeasurefromSTL - Online measurement tool - Open source
Thank you, i can see some uses for it, personally.
The following user(s) said Thank You: emresensoy
Time to create page: 0.208 seconds
