- Thank you received: 17
New LinuxCNC Multi-Channel System – Looking for Testers & Feedback
- hermann1976
3 weeks 6 days ago #350141
by hermann1976
The machine works on a component on the left machining table, while the next part can be set up on the right table simultaneously. Once setup is complete, the program is started and the table moves to a standby position. Only when the left-hand part is finished does the machining head move to the right to execute that program. At the same time, the left table moves out of the machining area to a parking position for re-setup.
There are also multi-head systems, and so on.
Replied by hermann1976 on topic New LinuxCNC Multi-Channel System – Looking for Testers & Feedback
I am indeed referring to a multi-channel control system.tommylight post=350129 Benutzer-ID=17274
hermann1976 post=350128 userid=26821
Es ermöglicht die erfolgreiche Nachrüstung älterer Maschinen —z. B. kompletter Homag-Holzbearbeitungszentren mit mehreren Tischzonen— unter Verwendung von LinuxCNC.
Ich bin mir ziemlich sicher, dass dies bereits möglich ist, siehe G55, G56 usw.
The following user(s) said Thank You: NWE
- Thank you received: 1480
3 weeks 6 days ago #350142
Replied by Todd Zuercher on topic New LinuxCNC Multi-Channel System – Looking for Testers & Feedback
At one point in the past I was getting quotes for buying a double router like that. In the end our company decided it was more cost effective and practical to simply buy two separate machines.
The following user(s) said Thank You: tommylight, NWE
3 weeks 6 days ago #350143
Replied by tommylight on topic New LinuxCNC Multi-Channel System – Looking for Testers & Feedback
I have to agree with Todd, such machine is much more versatile with two separate controls.
A nice local network with a NAS would also add a lot to functionality and ease of use.
3 weeks 1 day ago #350195
by Szumek
Replied by Szumek on topic New LinuxCNC Multi-Channel System – Looking for Testers & Feedback
Hi, I have a Gildemeister GDM 42 retrofitted with LinuxCNC, featuring two turrets and a sub-spindle. I’m looking forward to a solution like yours and would be happy to test it out.
- retrofitcenter
- Topic Author
- Thank you received: 20
1 week 4 days ago #350388
by retrofitcenter
Replied by retrofitcenter on topic New LinuxCNC Multi-Channel System – Looking for Testers & Feedback
Hi all,
a quick update from the multichannel LinuxCNC project I posted about earlier (looking for testers with real machines). Everything now lives on our new site: www.cnc.gmbh
What you'll find there:
Try it online – a live test environment where you can run the multichannel system in your browser, load programs for several channels and see how the synchronisation (wait marks, channel coordination, Sinumerik-style syntax) behaves, no install needed.
Download - the current .deb packages for Debian [12/13] (amd64, [arm64]) plus the full source code. Build instructions are included.
Config generation offer, since the most common question is "how do I get my machine running with it", we're offering, for a limited time, to generate the complete LinuxCNC configuration (INI/HAL, channels, axes, spindles, I/O) for your retrofit, works for existing LinuxCNC setups you want to migrate as well as brand-new retrofits. Send us your machine data and drive/IO hardware via the form on the site, and you get a ready-to-run multichannel config.
Feedback, bug reports and especially reports from real machines are very welcome, either here in this thread or via the site.
Thanks,
Daniel
Thanks,
Daniel
1 week 3 days ago #350400
by automata
Replied by automata on topic New LinuxCNC Multi-Channel System – Looking for Testers & Feedback
I registered on the site for trying the community edition.
But could not download the deb or the src to be able to try anything.
Even the link to the manual gives a 404 error.
I would appreciate a heads-up on this thread once you get a chance to get the site working.
Thanks,
-automata
Thanks,
-automata
Time to create page: 0.836 seconds
