Wireless round display for my EMCO F1-CNC (ESP32-S3 + LinuxCNC HAL over UDP)
17 Nov 2026 12:37 #350782 by DominicZe
Hi all,
I built a small wireless display for my EMCO F1-CNC retrofit and thought it might interest some of you.
It's a Waveshare ESP32-S3 with a 480x480 round touch screen, a 3.7 V 3000 mAh LiPo and a case I designed in Fusion. It shows spindle RPM, feed rate and XYZ, has a DRO with work and machine zero, and can control the spindle.
How it works on the LinuxCNC side:
- A Python HAL component sends the machine data over UDP.
- Commands from the display are signed with HMAC before LinuxCNC accepts them.
- An OTA server updates the firmware every time the display powers on.
- Firmware is C with LVGL.
The machine runs Probe Basic with my own conversational programming screens.
Video (Spanish, with English audio track and subtitles):
If there's interest, I'm happy to publish the project: the ESP32 firmware, the LinuxCNC component and the case files. What would you add to the display?
DominicZe
dominicze.com
  • Moderator
  • Moderator
17 Nov 2026 13:10 #350785 by tommylight
Very nice, thank you.
17 Nov 2026 14:37 #350787 by DominicZe
Thanks Tommy, glad you like it! And thanks for all the help you give here, I learned a lot from your posts while setting up my machines.
Next step is adding spindle load and the active tool number. Any other data you’d find useful on a small display like this?
DominicZe
  • Moderator
  • Moderator
17 Nov 2026 16:33 #350789 by tommylight
You are welcomed, always.
It's small things like this that make the daily work on such machines much more enjoyable, and now very cheap and readily available.
17 Nov 2026 16:41 #350790 by DominicZe
Couldn’t agree more. A cheap ESP32 board and a bit of HAL, and the machine is nicer to use every day.
I’ve just published the whole project in case anyone wants to build one or adapt it to their own machine: firmware, the LinuxCNC HAL component, the 3D printed enclosure (STEP/STL) and full design documentation:
github.com/DominicZe-DZ/linuxcnc-wireless-display
It’s read-only by default; the spindle/zero controls only work if you pair both sides with a key. Feedback welcome.
DominicZe
The following user(s) said Thank You: tommylight, rodw, Hakan
Time to create page: 0.583 seconds
