tool length probe subroutine for Probe Basic
  • TooTall18T
  • TooTall18T's Avatar Topic Author
  • Senior Member
  • Senior Member
08 Feb 2024 13:06 - 08 Mar 2025 07:40 #292871 by TooTall18T
I would like to introduce you to my Probe Basic subroutine project: tool length probe V5.0 .
All files can be seen and downloaded on github:
github.com/TooTall18T/tool_length_probe
For Probe Basic up to version 0.5.4-stable: github.com/TooTall18T/tool_length_probe/releases/tag/4.0.1
For Probe Basic Version 0.6.0-stable: github.com/TooTall18T/tool_length_probe/releases/tag/5.0.2
The subroutine is used to measure tools on a stationary tool length probe in LinuxCNC with the Probe Basic interface.
It doesn't matter whether the measurement is started manually from Probe Basic ([TOUCH OFF CURRENT TOOL]) or automatically from the milling program (M600).
There are optional settings for the process that extend the functionality of the original subroutine.
The machine is automatically freed and moves to the tool change point.
After confirming that the tool has been changed, the machine measures the tool and, if necessary, automatically returns to the starting point.
Things like the use of the tool table, the frequency of measurement attempts in the event of incorrect measurements or the position at which the tool is changed can be set individually.
An overview of the extensions compared to the original subroutine:
- Call using M command (M600)
- Use tool table
- Return to the starting point
- Pause at the starting point
- Switching off the tool spindle with selectable M command
- Additional repetitions in case of failed measurement attempts
- Last measurement without tool table
- Tool offset for larger diameters
- Alternative position for changing tools
- Alternative measurement position for 3D probes
The settings in Probe Basic can still be made there, the additional ones are made at the beginning of the subroutine.
For other GUIs all settings neet to be made in the routine.
Ideas for the future
Breakage test, comparison of value from the tool table with the last measured value
I would be happy to listen to further ideas and suggestions.
Last edit: 08 Mar 2025 07:40 by TooTall18T. Reason: Newer version(5.0.2) of the routine
The following user(s) said Thank You: spumco, Muftijaja, CNC_ANDI
  • TooTall18T
  • Senior Member
  • Senior Member
11 Feb 2024 09:05 #293098 by TooTall18T
Replied by TooTall18T on topic tool length probe subroutine for Probe Basic
I made new video for version 4.0 that can be seen on YouTube:
All my videos are in German because my English is not very well.
But I translated my chatter and made subtitles for this video because I know that it's not just German speakers who watch the videos about my routine.
I show how to set up Probe Basic with my subroutine and how it works.
The following user(s) said Thank You: tommylight, pommen, Muftijaja
07 Mar 2024 06:46 #295403 by Blume
Servus, Mega was du da so machst !
Falls du Lust und Zeit hast ich suche noch jemanden der mir beim einrichten mit Probebasic weiterhelfen würde.
Schöne Grüße
  • TooTall18T
  • Senior Member
  • Senior Member
07 Mar 2024 09:48 #295412 by TooTall18T
Moin, danke.
Wenn ich weiß wo der Schuh drückt, kann ich mal gucken was ich beisteuern kann.
Aber mach dafür bitte einen eigenen Beitrag auf, da es sonst hier OT wird.
Hast du dir das Video zum Einrichten von Probe Basic schon angesehen?
10 Jul 2024 12:29 #304837 by karlhe
Hallo,
ich habe mir Deine Videos mit probe basic angeschaut.
Gut erklärt, ich habe versucht probe basic in gmoccapy in meiner
Maschine zum Laufen zu bringen. Alles funktioniert prima, nur keine
Werkzeug-vermessung. Ich benutze linuxcnc 2.9 mit parallelport?
Hilfe bei Deiner Installation wäre prima.
Viele Grüße karlhe/ dieter heinrich
10 Jul 2024 12:39 - 10 Jul 2024 12:40 #304838 by Aciera
Schau mal hier betreffend 'Probe Basic' vs 'Probe Screen', hab ich doch schonmal was dazu geschrieben:
forum.linuxcnc.org/gmoccapy/52593-gmocap...gsam-taststen#300422
Last edit: 10 Jul 2024 12:40 by Aciera.
  • TooTall18T
  • Senior Member
  • Senior Member
26 Jul 2024 11:13 #306110 by TooTall18T
Die Subroutine ist aktuell nur auf den Gebrauch mit Probe Basic (GUI) ausgelegt.
Da du Gmoccapy benutzt, müsste man ein wenig die Routine umschreiben, oder in Gmoccapy einen Tab erstellen, der die Aufgaben des Tabs aus Probe Basic übernimmt. Da ich Gmoccapy aber nicht kenne, weiß ich auch nicht wie einfach oder schwer das ist.
  • TooTall18T
  • Senior Member
  • Senior Member
20 Oct 2024 07:27 #312667 by TooTall18T
With the release of Probe Basic 0.6.0 they changed their tool measurement routine and now they also use the .var-file to store the settings.
Unfortunately, this leads to overlaps and my routine (V4.0) is no longer compatible with version 0.6.0 of Probe Basic.
It will take some time until I get around to adapting and testing everything.
As soon as I'm done there will be a new version and I'll let you know.
  • TooTall18T
  • Senior Member
  • Senior Member
10 Dec 2024 12:44 - 24 Feb 2025 13:15 #316423 by TooTall18T
I opened a develop-branch for a updated version of my subroutine.
Version 5.0.0 will be for Probe Basic 0.6.0 (and hobefully higher) and can also be used with every other GUI.
Using M600 Tx(tool change and measurement) and M601(only measurement) the subroutine can be controlled from any GUI.
You can find all files here:
github.com/TooTall18T/tool_length_probe/tree/develop
It is now a release version:
github.com/TooTall18T/tool_length_probe/releases/tag/5.0.1
Last edit: 24 Feb 2025 13:15 by TooTall18T.
  • TooTall18T
  • Senior Member
  • Senior Member
06 Feb 2025 11:10 #320837 by TooTall18T
I made the 5.0.0 develop to the main branch and made a release for it.
The way the routine works is the same as you can see in the video of version 4. Also the way to install it is the same.
I was not able to make a version that is usable with all versions of Probe Basic. So I need to make a cut.
Version 4.0.1 is for Probe Basic up to 0.5.4-stable.
Version 5.0.0 is for Probe Basic 0.6.0 and it is also usable with every other GUI.
The following user(s) said Thank You: Muftijaja
Time to create page: 0.142 seconds
