tool length probe subroutine for Probe Basic
  • TooTall18T
  • TooTall18T's Avatar Topic Author
  • Senior Member
  • Senior Member
24 Feb 2025 12:35 #322513 by TooTall18T
Replied by TooTall18T on topic tool length probe subroutine for Probe Basic
It all took a little longer, but I have a presentable development status for version 6.0.
In Probe Basic, the tool measurement routine can now be fully configured via its own user tab.
The page also contains a subpage with a little help on the settings.
The settings are no longer communicated via parameter file (.var), but via HAL pins. The parameter file now functions as a backup. Either because you want to test other values ​​or as a security backup.
Using the installation script, the files and folders can be quickly edited and moved to their location. Of course, a backup of all files is created. In the test phase, however, it might not be a bad idea to back up the machine folder completely.
LinuxCNC min 2.9.3, Probe Basic min 0.6.0-37.dev and QTPYVCP min 5.0.2-5.dev are required.
Nothing has actually changed in the routine's processes and no new functions have been added yet. Nevertheless, the routine for the connection to the GUI has been revised.
What has changed, is the way in which the offset is created for tools with a large diameter. An offset is no longer created across the board from a certain diameter, but a value is entered in percent in the "FNT ANGLE" column in the tool table. This means that each tool can be offset individually.
You can find everything here: github.com/TooTall18T/tool_length_probe/tree/develop
The routine itself can also be used without Probe Basic (user tab). Information about this can be found in the manual.
The following user(s) said Thank You: tommylight, Haarie, Muftijaja
20 Oct 2025 03:29 - 20 Oct 2025 10:05 #336738 by Edi_48
Hallo ich habe deine Installation gemacht,
Fahren auf Referenfpunkt geht
Fahren auf G30 ist Ok
Werkzeug wechsel geht nicht Fehler :Kein Werkzeug in Carosell
In der ini habe ich bei ATC_TAB_DISPLAY= 0 , Atc Pockets=0
Frage wo ist der Fehler
Last edit: 20 Oct 2025 10:05 by Edi_48.
  • TooTall18T
  • Senior Member
  • Senior Member
21 Oct 2025 13:38 #336843 by TooTall18T
Hi
Welche Versionen benutzt du gerade?
LCNC, Probe Basic und meine Routine
Hast du vielleicht in der Werkzeugtabelle noch die Pockets aktiv? Ich weiß nicht ob es relevant ist, ist jetzt erstmal nur eine Idee.
Muss gestehen, dass mir der Fehler neu ist.
23 Oct 2025 02:36 #336942 by Edi_48
LCNC 2.9.6
tool_touch_0ff 6.0.0
ProbeBasic neuste Version
Werzeugtab nur 1 Werkzeug neu angelegt
tool_touch_0ff ich habe es auch mit der Version 0.3 Von Cris und Dir
  • TooTall18T
  • Senior Member
  • Senior Member
23 Oct 2025 12:18 #336968 by TooTall18T
Hat es vor der Installation von meiner Routine funktioniert?
Einen Werkzeugwechsler hast du ja scheinbar nicht, hast du den manuellen Wechsle in der HAL drin?
Funktioniert die manuelle Vermessung über [Touch off current tool] bzw. M601?
Time to create page: 0.097 seconds
