I am trying to adapt `qt_auto_probe_tool.ngc` to offset large tools and measure at the edge. I get "Internal error: unable to assign #<offset_amount>". I have added the variables to the .ini file under [VERSA_TOOLSETTER].
I am not sure what's going on. Is it a scope issue and I am not setting it in the proper location? Are the variables from the ini file not being parsed?
Also, is there any way to debug this step by step instead of trying it and getting the error out of the gui?
o<qt_auto_probe_tool> sub
; IMPORTANT: this remap enables using a gcode/ngc program on machines without
; automatic tool changers, and without repeatable tool holders, but which
; do have a tool setter (and ideally, an xyz probe).
; With this remap, a program or user can issue TxM6 commands at any
; point and the machine will automatically do the following:
; 1. Move to a tool change position defined in .ini parameters, Z first, then XY
; 2. Perform the normal M6 tool change (IE stop spindle, prompt for tool)
; 3. Move to the location of the toolsetter, Z first, then XY, probe the new tool's offset
; 4. Change the offset of the current coordinate system to match the new tool
; 5. Return the tip of the new tool to the same spot as the tip of the old tool
; based on newly measured z-offset
; 6. Return control back to whatever state it was in prior, continuing the program
; if one had been running.
; The following settings should be enabled in the QtDragon interface:
; A - Under Probe Tool screens: insure that "Tool Measure" is enabled
; B - Under Settings: insure that "Use Tool Sensor" is enabled
; The following workflow assumes using both a XYZ probe and a Z Toolsetter:
; 1 - Initial Setup: Before beginning the program, setup the Probe Tool as
; having a zero z-offset in the tool table. (Non-zero tool lengths
; for the probe tool can be made to work, but have multiple extra
; steps required, and it is easy to have the tool offset interfere with
; the remap coding and cause incorrect adjustments to your offsets.
; This procedure assumes a zero length.)
; 2 - Initial Tool: Load the probe tool with M61 Qx, where x is the Probe tool's number
; in the tool table. (Do not use TxM6)
; 3 - Toolsetter measure: Use button under the Probe Screens for "Probe Tool Setter
; Z Height:" this will set and display on the Probe Settings screen the
; "Probe HT" = #<_hal[qtversaprobe.probeheight> value in ABS coordinates.
; 4 - Workpiece Measure: Use the button under the Probe Screens for "Probe Z height
; of material:" this will set and display on the Probe Settings screen the
; "Block Ht" = #<_hal[qtversaprobe.blockheight]> value in ABS coordinates.
; 5 - Set Coord System (G54): Use the Probe Tool and whichever probe screen is
; appropriate to set the coordiate system XYZ offsets needed for your job.
; NOTE: Return_Option 3 uses the current local coordinate system, not just ABS coord.
; 6 - Prepare to Run: You may then issue a manual TnM6 command to change the tool
; before starting the job, or if the job begins with a TnM6 command before
; spinning the spindle, you may leave the Probe Tool installed.
; !! Take care not to leave the XYZ tool probe in the spindle when a program may start
; the spindle. !!
(debug, in change tool_in_spindle=#<tool_in_spindle> current_pocket=#<current_pocket>;)
(debug, selected_tool=#<selected_tool> selected_pocket=#<selected_pocket>;)
; --- Begin Initial data gathering ----
#<tool> = #<selected_tool>
#<pocket> = #<selected_pocket>
#<local_start_x> = #<_x>
#<local_start_y> = #<_y>
#<local_start_z> = #<_z>
#<toolsetter_diameter> = #<_ini[VERSA_TOOLSETTER]TOOLSETTER_DIAMETER>
#<offset_direction> = #<_ini[VERSA_TOOLSETTER]OFFSET_DIRECTION>
#<offset_amount> = 0 ; initialize offset amount to zero.
; --- End Initial Data Gathering ----
; --- Begin Initial Safety Checks ----
; we must execute this only in the milltask interpreter
; or preview will break, so test for '#<_task>' which is 1 for
; the milltask interpreter and 0 in the UI's
o100 if [#<_task> EQ 0]
(debug, Task is Null)
o100 return [999]
o100 endif
; check we are in right mode
o110 if [#<_metric_machine>]
o115 if [#<_imperial>]
(MSG, Auto Tool probe error: not in G21 mode )
o115 return [-3] ; indicate probe contact failure to epilog
o115 endif
o110 else
o115 if [#<_imperial> EQ 0]
(MSG, Auto Tool probe error: not in G20 mode )
o115 endif
o110 endif
;check we have a usable search velocity configured, otherwise error
o150 if [#<_hal[qtversaprobe.searchvel]> LE 0]
(MSG, No usable search velocity in hal.qtversaprobe.searchvel)
o150 return [-1] ; indicate searchvel <= 0
o150 endif
;check we do not have an invalid Return Option
o175 if [EXISTS[#<_ini[VERSA_TOOLSETTER]RETURN_OPTION>]]
#<return_opt> = #<_ini[VERSA_TOOLSETTER]RETURN_OPTION>
o176 if [[#<return_opt> EQ 1] OR [#<return_opt> EQ 2] OR [#<return_opt> EQ 3]]
;Continue: Return_Option is both defined and valid
o176 else
(MSG, Invalid RETURN_OPTION in .ini file under VERSA_TOOLSETTER)
o176 return [-1] ; signal error to post processing
o176 endif
o175 else
;Continue: it is valid to not define Return_Option, defaults to 1
o175 endif
; --- End Initial Safety Checks ----
; --- Begin Physical Tool Change ----
;first go up
F #<_hal[qtversaprobe.searchvel]>
G53 G0 Z[#<_ini[CHANGE_POSITION]Z>]
o200 if [#<_current_tool> NE #<tool>]
; then move to change position
G53 G0 X[#<_ini[CHANGE_POSITION]X>] Y[#<_ini[CHANGE_POSITION]Y>]
o200 endif
;cancel tool offset mode
G49
; using the code being remapped here means 'use builtin behaviour'
; ie, this is not a recursive call to this program, but calls the
; un-remapped M6 processing
; That processing includes actually sending the window to the user
; to press OK when they have completed the tool change.
M6
; ------ End Physical Tool Change ----
; ------ Begin Safety Checks for Tool Offset Measurement ----
o300 if [#<_hal[qtversaprobe.enable]> EQ 0]
(MSG, Auto Tool probe disabled )
G43 ;turn back on tool offset mode before returning
o300 return [3] ; indicate no tool measurement
o300 endif
;check we have a usable probe velocity configured, otherwise error
o400 if [#<_hal[qtversaprobe.probevel]> LE 0]
o400 return [-2] ; indicate probevel <= 0
o400 endif
; ------ End Safety Checks for Tool Offset Measurement ----
; ------ Begin Tool Offset Measurement ----
;rapid-move to safe height
G53 G0 Z[#<_ini[VERSA_TOOLSETTER]Z_MAX_CLEAR>]
;Then rapid-move to probe XY location
G53 G0 X[#<_ini[VERSA_TOOLSETTER]X>] Y[#<_ini[VERSA_TOOLSETTER]Y>]
; --- Start of new code for diameter compensation ---
M1 ; Option stop for debugging
0440 if [is_number[#<toolsetter_diameter>]]
o450 if [#5410 GT #<toolsetter_diameter>]
#<offset_amount> = [[#5410 - #<toolsetter_diameter>] / 2]
(debug, tool diameter=#5410)
(debug, toolsetter diameter=#<toolsetter_diameter>;)
(debug, offset amount=#<offset_amount>;)
o451 if [#<offset_direction> EQ 1]
G53 G0 X[#<_ini[VERSA_TOOLSETTER]X> + #<offset_amount>]
o451 elseif [#<offset_direction> EQ 2]
G53 G0 X[#<_ini[VERSA_TOOLSETTER]X> - #<offset_amount>]
o451 elseif [#<offset_direction> EQ 3]
G53 G0 Y[#<_ini[VERSA_TOOLSETTER]Y> + #<offset_amount>]
o451 elseif [#<offset_direction> EQ 4]
G53 G0 Y[#<_ini[VERSA_TOOLSETTER]Y> - #<offset_amount>]
o451 endif
o450 endif
o440 else
(debug, tool_diameter=#<tool_diameter> toolsetter_diameter=#<toolsetter_diameter>;)
(MSG, tool_diameter or toolsetter_diameter is not a number)
o440 endif
; --- End of new code for diameter compensation ---
;then feed down to the probe start location
G53 G1 Z[#<_ini[VERSA_TOOLSETTER]Z>]
;switch to relative distance mode for probe moves
G91
;begin initial probe move
G38.2 Z- #<_ini[VERSA_TOOLSETTER]MAXPROBE>
G0 Z #<_hal[qtversaprobe.backoffdist]>
o510 if [#5070 EQ 0]
G90
o510 return [-3] ; indicate probe contact failure to epilog
o510 endif
;reprobe at probe speed: G38.2 means probe toward workpiece, stop on contact
; when G38.n axis completes, it puts the Z value detected (in the coordinates system
; in which this program started) into parameter #5063 (because we're probing Z)
F #<_hal[qtversaprobe.probevel]>
G38.2 Z- [#<_hal[qtversaprobe.backoffdist]> *1.2]
o511 if [#5070 EQ 0]
G90
o511 return [-3] ; indicate probe contact failure to epilog
o511 endif
;switch back to absolute distance mode once probing is done
G90
;set the current offset
#<touch_result> = #5063
; G10 L1 is the Set Tool Table Offset: it changes the tool table offset,
; it DOES NOT change the offsets in the current coordinate system. (that would be G10 L2)
#<calculated_offset> = [#<touch_result> - #<_hal[qtversaprobe.probeheight]> + #<_hal[qtversaprobe.blockheight]>]
G10 L1 P#<tool> Z[#<calculated_offset>]
;G43 enables tool length offset: this affects all subsequent moves by applying
; the offset just calculated to the coordinate system currently in
; effect. ie. it has subtracted Calculated Offset from the Z offset
G43
(DEBUG, %fProbe Height: #<_hal[qtversaprobe.probeheight]>;)
(DEBUG, %fBlock Height: #<_hal[qtversaprobe.blockheight]>;)
(DEBUG, %fProbe Result: #<touch_result>;)
(DEBUG, %fCalculated Offset: #<calculated_offset>;)
; ------ End Tool Offset Measurement ----
; ------ Begin Return Movement ----
; return to original tool-tip position, but using new z-offset
(DEBUG, Return to original tool-tip position using new z-offset: #<local_start_x> , #<local_start_y> , #<local_start_z>;)
; now use original (modal)coord system to go over to xy
G0 X[#<local_start_x>] Y[#<local_start_y>]
;M1 ; Option stop for debugging
; and finally down to the (already offset) z coord
;G0 Z[#<local_start_z>]
; ------ End Return Movement ----
; signal success be returning a value > 0:
o<qt_auto_probe_tool> endsub [1]
m2
