disable dangerous keyboard jogging!
28 Nov 2023 01:38 #286651
by phillc54
linuxcnc.org/docs/devel/html/plasma/qtpl...a:keyboard-shortcuts
We also have fairly restrictive keyboard focus dependent on which widget has focus. e.g. if the edit widget is opened then all keystrokes go to the edit widget so that jogging is not possible while editing.
Replied by phillc54 on topic disable dangerous keyboard jogging!
This will be of no value to you with your machine types but this is what we have in QtPlasmaC.If there's one addition to the LCNC manual which might be helpful... a simple statement (somewhere) that keyboard controls are managed by the GUI, and are frequently located in some python file... not in an obvious front end setting. Otherwise, each GUI dev or team will have to manage how, if at all, to discuss/document keyboard controls.
28 Nov 2023 02:57 #286656
by spumco
Replied by spumco on topic disable dangerous keyboard jogging!
Thanks again Phil.
I'm not married to PB, Axis, or any other GUI at this point. I may wind up cooking up my own GUI, based on qtvcp or qtpyvcp... in which case the QTPlasmaC scheme will likely be valuable/
28 Dec 2023 08:32 #289233
by Gordon49
Replied by Gordon49 on topic disable dangerous keyboard jogging!
A issue with touchscreens is that not everybody is able to use them safely. Give my wife a touch screen device such as a phone or ipad and by just putting a finger near the screen everything goes bananas!!
Trouble is it is a random problem and does not happen every time even on the same device.
Machine tools need to be safe. My drives are on a separate power supply and are turned off at boot. Once the control panel is loaded I then start the motor supply, and to date have never had a problem with this way of working.
I suppose having a separate control panel as the Hass and other commercial machines is another option but is expensive.
Not everybody has unlimited funds available.
Using a mouse only to control the machine is inconvenient and as long as you are aware of any dangers a keypad or keyboard can be used safely.
But each individual needs to find the best solution for themselves.
28 Dec 2023 14:35 #289247
by zmrdko
Replied by zmrdko on topic disable dangerous keyboard jogging!
How about changing jogging keyboard shortcut to ctrl + arrow? That might eliminate a lot of unwanted jogging.
28 Dec 2023 16:45 #289263
by spumco
Someone building a little 500w router with Nema 17 steppers and 60ipm rapids might be seriously dismayed if they needed a dedicated control panel just to test the thing out.
At the other extreme, someone retrofitting a 20hp lathe with 1000ipm rapids and $10k+ worth of tooling in the turret might be appalled at the thought of a stray keyboard (or touchscreen) click scrapping a part or crashing the machine. They want dedicated controls, clearly marked, and requiring a very intentional press/click/twist to engage.
My preference would be to have an easily accessed setting to enable/disable keyboard controls, perhaps on a by-function basis. Those users who have a desire for full keyboard control can leave things as-is, and those of us who want to eliminate all keyboard jogging & machine functions can do so without needing to dig through multiple python files and decrypt/edit the keybinding scheme.
I suspect the problem is that because LCNC can accept external commands from GUI programs (via python or whatever), all keyboard interaction is dependent on the GUI implementation. As others have pointed out some GUI frameworks are better than others at describing the keybinding scheme.
I've no idea if LCNC can be modified to optionally reject keyboard commands from an external source - and if that would result in the GUI reporting errors or other unintended consequences.
That would be a good start, but it would likely annoy users who want - and are used to - keyboard control of the machine.How about changing jogging keyboard shortcut to ctrl + arrow? That might eliminate a lot of unwanted jogging.
28 Dec 2023 20:59 #289281
by cakeslob
Replied by cakeslob on topic disable dangerous keyboard jogging!
keyboard jogging is fine, its all on how its implemented. But yeah, a good solution might be an INI option to disable keyboard shortcuts.
Exactly, it sounds less like a keyboard jog issue and more a gui issue. why arent all the keybinds being handled when the entry takes focus?
not just the < > arrows but the v ^ pgup and pgdown
Time to create page: 0.094 seconds
