Manual tool change + tool lengh touch off
27 Nov 2010 21:47 #5672 by andypugh
axel88 wrote:
which hal file?
/usr/share/emc/tcl/bin/halconfig.tcl?
EDIT: /home/axel/emc2/configs/Portalfrase/Portalfrase.hal looks good, right?
Yes, I came into the forum at a run to make sure you weren't about to do something silly.
(I had to delete your umlauts as the forum refuses to show any message with odd characters at all, including three full stops in a row, and the UK currency symbol)
You can either edit that file, or if it was created by stepconf you can put your new stuff in the custom.hal file where stepconf won't over-write it.
The drawback with putting it in the custom.hal file is that you might need to unlink some connections to insert your new stuff.
unlinkp parport.0.pin-10-on-not
unlinkp motion.probe-input
Would do that.
HAL is one of the most powerful features of EMC2, it allows you to connect any inputs and any outputs together in a completely free way, optionally processing the signals on the way.
28 Nov 2010 09:41 - 28 Nov 2010 09:43 #5677 by axel88
1.) By moving the debounce procedure to the custom.hal I've got some errors:
CUSTOM.HAL (line 4 to 10)
unlinkp parport.0.pin-10-in-not
loadrt debounce cfg=1
addf debounce.0 base-thread
setp debounce.0.delay  10
net probe-raw parport.0.pin-10-in-not => debounce.0.0.in
net debounce.0.0.out => motion.probe-input
ERROR:
custom.hal:10: Signal name 'debounce:0.0.out must not be the same as pin.
8635
Last edit: 28 Nov 2010 09:43 by axel88.
28 Nov 2010 10:15 - 28 Nov 2010 10:18 #5678 by axel88
2.) I've got problems with the subprograms:
I wrote to files: first-tool.ngc and auto-tool-change.ngc and located them in ../emc/nc-files which is defined as the PROGRAM_PREFIX folder in the Portalfrase.ini .
when I run:
o<first-tool.ngc> call
or
o<first-tool> call
the error "File not open" appears.
here is my subprogramm:
o<first-tool> sub
G90 G53 G0 Z0
G53 G0 X0 Y0
G91 G38.3 Z-180 F500
G38.5 Z10 F15
#1000=#5063
G90 G53 G0 Z100
G90 G53 G0 X50 Y50
o<first-tool> endsub
M02
But even if I copy the fred.ngc example it doesn't work.
Last edit: 28 Nov 2010 10:18 by axel88.
The following user(s) said Thank You: bob8020
28 Nov 2010 13:17 - 28 Nov 2010 13:39 #5681 by andypugh
Sorry, I didn't put the signal name in the net statement, so the interpreter is trying to use the first pin name as a signal name
You need something like
net FreelyChosenSignalName debounce.0.0.out => motion.probe-input
The signal names are conceptually equivalent to the colours of the wires in a physical system, you can choose any you want, but it helps understand the system if they match the function. (Also you can't have more than one signal with the same signal name)
Last edit: 28 Nov 2010 13:39 by andypugh.
28 Nov 2010 13:20 #5682 by andypugh
The problem might be the hyphen in the name. (Just a guess). Try it without that. The way that filenames get passed through the G-Code interpreter is a bit messy, they get changed to all lower-case and spaces get removed, the same might be true for "operators".
28 Nov 2010 13:36 #5683 by axel88
net motion.probe.input <= debounce.0.0.out
I thought I tried this at first, but so it worked.
The hyphen is not the reason, I've already tried it without and the fred.ngc has none either.
28 Nov 2010 13:51 #5686 by axel88
It seems to work if i call o<first-tool> call in a *.ngc file, but I can't run it from the MDI console. But this should be enough for the postprocessor.
28 Nov 2010 13:56 #5687 by andypugh
Which EMC2 version are you running?
I vaguely recall an improvement in the way it searched for subroutines, but that was rather a long time ago.
I just did a test:
In the ini file I have PROGRAM_PREFIX = /home/andypugh/emc/nc_files
In the nc_files directory I have:
test1.ngc
test.ngc
test1.ngc contains:
o<test> call
m2
test.ngc contains:
o<test> sub
(debug, We got here)
o<test> endsub
m2
And it all "just works" with version 2.3.5
Incidentally, the dev list was busy last night sorting out an issue with probing in subroutines. I think it is only a problem when the subroutine is called from MDI_COMMAND, but I have asked for clarification. The issue is one of returning before the end of the probe, I think, so not related to your general subroutine problem.
28 Nov 2010 14:12 - 28 Nov 2010 14:13 #5688 by BigJohnT
You could use something similar to my touchoff file that I use on my plasma torch.
move to start point of the cut...
o<touchoff> call [0.080] [0.02] [0.06] (Touchoff and start torch)
my touchoff.ngc file:
o<touchoff> sub
(#1 pierce height, #2 pierce delay, #3 cut height)
F10
G38.2 Z-1.75 (Probe to find the surface)
G91
G1 Z0.070 (Raise up to Z0)
G90
G92 Z0 (Set Z0)
G1 Z#1
M3 S1
M66 P0 L1 Q5 (Wait for Arc OK from Torch)
G4 P#2 (Pause for pierce delay)
F25
Z#3 (goto cut height)
o<touchoff> endsub
M2
Last edit: 28 Nov 2010 14:13 by BigJohnT.
28 Nov 2010 14:40 #5690 by andypugh
Ah, yes. I didn't realise that you were calling it from MDI. I just tried it in version 2.4.3 and it worked fine. Perhaps you are using 2.3?
Time to create page: 0.259 seconds
