Hurco BMC 20 Ultimax 3 Retrofit
03 Jun 2015 08:54 - 06 Dec 2015 14:04 #59364
by Jake
Hurco BMC 20 Ultimax 3 Retrofit was created by Jake
I will make this the beginning of the official retro thread
Yasakawa CACR servo drives, analog input
Quadrature encoders on everything
It is the Ultimax 3 control
Thanks guys!
Thanks guys!
Last edit: 06 Dec 2015 14:04 by Jake.
04 Jun 2015 05:24 #59406
Replied by andypugh on topic Hurco Mill retrofit
[quote="Jake" post=59364They are supposed to be Baldor DC brushed servos with encoders. I am imagining the servo amps are analog input.[/quote]
That sounds like a fairly simple retrofit. You will still need a +/-10V card for LinuxCNC, though. Are you assuming that the Pico stuff will turn up, or not?
04 Jun 2015 05:35 #59408
by Jake
Replied by Jake on topic Hurco Mill retrofit
Supposedly the machine ran right before they dragged the block over it. So there should be good parts. I wanted a bed mill but these are about the heaviest knee mill you can get and the price is right. It appears to be a low hour machine also.
I hope the Pico parts show up, I want them. But three weeks and nothing from the seller at all makes me wonder.
I dont have the machine at the shop yet so if the Pico gear does not show up by then I will get a battle plan together for that. I need to get a hold of Jon, to see if his brushed amps will work with those servos, there 150v max and 16 amp continuous. Big brushed Baldors
Thanks Andy!
Thanks Andy!
04 Jun 2015 06:02 #59409
Keep the existing amps.
They are almost certainly velocity-mode drives with tacho feedback to the drives. No point changing that.
05 Jun 2015 00:30 #59436
by Jake
They should be one of the Servo Dynamics servo amps in there. He is supposed to get me some additional pictures when he gets a chance.
On hardware, would one of the Mesa plug-n-go kits like a 7i67-5i25 get the job done to go from the PC to the machine?
I think I am at the point with the Ebay gear that I am just going to get my money back and be done, and get the planning rolling on this machine.
Thanks Andy!
Thanks Andy!
05 Jun 2015 00:39 #59438
7i77 / 5i25 ought to work, or you could stick with Pico and use the PPMC with the existing amps.
But wait to see if the amps work first, you can test them with a battery.
21 Jun 2015 05:45 #60023
by Jake
Well it looks like I am going to pass on the Hawk, more money than I want to spend on a knee mill.
There is a BMC20 VMC that I have my eyes on. If I can get it for the right price I am going to get it. 7.5hp 6k spindle, Fanuc red cap servos, tool changer. It hasn't run in a long time, allegedly the board have been checked out by a CNC tech and there supposed to be functional. The machine is in a totally manual shop and the guy that runs the shop knows virtually nothing about it. All the manuals are with the machine. So i will see what I can come up with on it. Its about the ideal machine that I have wanted. I have wanted a 40" X, 20" Y 20" Z machine with a 10HP ~ 10K spindle, covers me for everything I would want to do but without going huge, on size, weight, and power requirements.
24 Nov 2015 17:51 #65745
by Jake
Well it looks like I am going to close the deal on the BMC20. I finally have him down on price where I am willing to give for it. !
Hopefully I will have it in the shop in a couple weeks. We will see.
Then I can really pester the hell out of yall on the retrofit!
24 Nov 2015 18:01 #65747
by piasdom
Replied by piasdom on topic Hurco Mill retrofit
Good Luck on the retrofit !
The following user(s) said Thank You: Jake
24 Nov 2015 18:06 #65748
by Jake
Thanks! I am sure I will need it!
Moderators: piasdom
Time to create page: 0.219 seconds
