Hurco BMC 20 Ultimax 3 Retrofit
09 Feb 2016 13:45 #69844
Have you tried hard-wiring the enables? ie, physical bits of wire, no relays, no complications?
Replied by andypugh on topic Hurco BMC 20 Ultimax 3 Retrofit
Still no luck. Tripled checked the wiring, and conditions. Still can not get it out of base block. .
09 Feb 2016 13:56 #69845
by Jake
Replied by Jake on topic Hurco BMC 20 Ultimax 3 Retrofit
Yeah I have. Last night I had (8 servo enable) ( alarm return), (two limits) all tied directly to 0v with no change.
The servo is also not in alarm condition. When you put 208 power to the servo the alarm relay closes like it would in a normal condition.
I just can't get the truck out of park!
I have 10 wires on my connector to the servo pack which are all accounted for. The only ones I have not terminated are the torque meters. I have not built the A-D converters for yet. I did get a couple Arduino boards in the other day. Maybe it sensing that there is no torque meter connected won't allow a run? I can't find where it says if that is a permissive. All the Allen Bradley drives I have dealt with all you had to do for motion was 24v in and connect the enable and direction permissive to 0v and you were in business.
Every other little issue on this machine has been no big deal, it's frustrating when this is the big milestone that has me STUCK.
Hopefully I'll hear from Yasakawa today.
09 Feb 2016 14:19 #69847
by Jake
Andy,
Do you have more information on the Arduino analog to digital with interface to the PC?
Thanks!
Thanks!
09 Feb 2016 14:36 #69849
I have read back through the thread, and I have no idea what this question is about.
Can you eleborate?
You shouldn't need any A to D. Only the drives need to know about the tachs.
Can you eleborate?
09 Feb 2016 14:50 #69851
by Jake
My servo drives have a analog torque output. I want to send that torque output to LCNC, so I can have meters or a trip function if the servo or spindle torque gets to high. You had mentioned that someone had done that with an Arduino and interfaced it with the Linux CNC. This was actually very far down the list, as the machine should function just fine without them. It will just be a nice feature to have in the future. Especially where your doing some aggressive material removal and your can see how hard your pushing the machine and tailor your code to work within the boundaries.
I originally mentioned that torque output signal thinking it might cause a permissive but I wouldn't think so.
Can you eleborate?
09 Feb 2016 16:14 #69856
Are there any ADC options on the Pico board? You could potentially look at voltage-to-frequency and use a spare encoder input.
For an Arduino solution:
emergent.unpythonic.net/01198594294
My servo drives have a analog torque output. I want to send that torque output to LCNC, so I can have meters or a trip function if the servo or spindle torque gets to high. You had mentioned that someone had done that with an Arduino .
09 Feb 2016 17:37 #69866
by jmelson
(And, no, the Pico Systems PPMC does not feature any analog input.)
Jon
Replied by jmelson on topic Hurco BMC 20 Ultimax 3 Retrofit
Well, I've never heard this base block term before. Does the machine move at all, even a tiny bit? Can you connect a DVM to the velocity command wire to the servo amp and see what it is getting? Possibly if the ground return for the velocity command is not right, it could think it is getting a large signal there, which might be interpreted as an error condition. Maybe you could disconnect from the DAC board and short the velocity input to the velocity ground and see if it will power up without going into the base block state.Still no luck. Tripled checked the wiring, and conditions. Still can not get it out of base block. Moving the alarm circuitry over to the 24v did not have any affect either. I'll move it back to the PPMC tonight as it was functioning correctly there. Changing MINFERROR did give it more time to try to move.
Jon
09 Feb 2016 18:11 #69873
by Jake
Nope no movement at all. the servo motors are stone cold also.
When the controller is calling for a movement command an additional light comes on the servopack
I did try swapping the leads on the DAC and that did not work either.
I will put a meter on it tonight and try with it disconnected from the DAC also.
I just got off the phone with Yasakawa. They said as long as my 24vdc+ is on 7, and I have 8, 26, 41 connected to 0v it should be fat dumb and happy. I don't need the torque signal or the alarm signal hooked up to anything.
10 Feb 2016 04:18 #69909
by Jake
im a retard.
Well I had 24vdc to the drive, 208 single phase, but no 208 three phase to the drives. I had originally thought the one switch in the cabinet turned both the single and 3 phase to the servos on. There was another contactor that sent the 3ph to the servo packs.
I do have an overload alarm on the x, and z. So I am going to troubleshoot those tomorrow and go from there. Thanks guys!
10 Feb 2016 11:15 #69920
Things like this are only obvious once you have spotted them.
I spent much of last night disassembling and troubleshooting my servo PSU. Eventually I noticed that the breaker on the wall had tripped....
im a retard.
Moderators: piasdom
Time to create page: 0.250 seconds
