Changing the openGL colors in the Axis GUI
17 Apr 2020 05:10 - 17 Apr 2020 05:11 #164234
by phillc54
Replied by phillc54 on topic Changing the openGL colors in the Axis GUI
I have updated the test branch with your latest version
forum.linuxcnc.org/21-axis/16426-changin...-gui?start=90#162637
Colour changes worked and stayed for the next run.
What is the purpose of the ticker?
I really don't like the X in the bottom corner, it is a bit unexpected (for me) to have an exit there. If you insist on having it then you should at least create a tooltip for it and maybe give it a warning colour like the ESTOP on the left. Actually I think you should get rid of it as there are already enough ways to exit.
Last edit: 17 Apr 2020 05:11 by phillc54.
17 Apr 2020 05:59 - 17 Apr 2020 06:15 #164235
by zack
Replied by zack on topic Changing the openGL colors in the Axis GUI
On my touchscreen the exit button is a bit small on the top right so I have it bottom right.
With no Keyboard and mouse around input cntr-q/Q is not an option.
If you have another suggestion i will revise the position or solution.
maybe exit word instead?
Any other suggestions or revisions more than welcome, the numerous installs I have done with axis,
namely on gantry routers, users seem to request a return home and larger buttons.
Most generate g-code with a post processor so do not frequently read the g-code, hence the option Cntr-h
to hide the code pane. Cntr-g to show it again.
How many users have touchscreens, I wonder? It might be plausible to add a pop up input panel with a revised
keyboard for the MDI pane, any thoughts. Should it double as a touchy type interface as well?
Last edit: 17 Apr 2020 06:15 by zack.
17 Apr 2020 06:29 #164236
by phillc54
It would be nice if the Control+h was a toggle rather than requiring both Control+h and Control+g
Ahh, that explains it. I think touchscreen is the only downfall of Axis. In that case I am not sure what the answer is but Exit would be better than Xtouchscreen
The following user(s) said Thank You: zack
17 Apr 2020 07:19 #164238
by zack
Ok will ammend
17 Apr 2020 08:11 #164243
by Clive S
That fooled me. I had to look it up.
Replied by Clive S on topic Changing the openGL colors in the Axis GUI
Some docs below (restricted to English, my only other language is Strine)
17 Apr 2020 09:50 #164247
Replied by rodw on topic Changing the openGL colors in the Axis GUI
Clive, I can't believe this is still in my gmail after 10 years BUT:
Seeing you've now visited down under,
Before mastering Strine you need to pass our citizenship test. See attached....
Its quite an enlightening insight into Strine and Aussie Slang. But I'm sure it will be lost on non-residents of this great country
17 Apr 2020 10:06 #164248
by Clive S
I give up !! Q.16 beetroot
17 Apr 2020 10:12 #164249
by phillc54
That was a trick question, betroot should be in every hamburger.
17 Apr 2020 10:17 #164250
Absolutey!!! None of this pickles cr#p!
17 Apr 2020 20:30 - 24 Sep 2023 15:24 #164324
by zack
Good on ya, mate!updated file don't forget to rename it to .tclbeefy
Last edit: 24 Sep 2023 15:24 by zack.
