Axis Position Logger
10 May 2022 12:03 #242481
hosted.weblate.org/projects/linuxcnc/linuxcnc/#translations
You can help
Replied by andypugh on topic Axis Position Logger
This should soon be almost automatic:I didn't find it, but I did it. Slovak language.
forum.strojirenstvi.cz/viewtopic.php?t=31115
You can help
10 May 2022 12:06 #242482
Do you have Python3 installed? 2.9 / master is 100% Python3 now.
How are you switching versions? Are you reinstalling linuxcnc-uspace-dev after switching?
I don't really know. It is almost certainly related to Python2 / Python3I've been working on it for a week. Does anyone know why it can't find the linuxcnc module?
13 May 2022 05:57 #242854
by jurod
Replied by jurod on topic Axis Position Logger
I switch versions by reinstalling linuxcnc-uspace-dev. I have Python3 and Python2.7 installed.
13 May 2022 23:58 #242921
Switching linuxcnc-uspace-dev should come after switching LinuxCNC versions, I think.
21 May 2022 13:54 #243473
by jurod
Yes.
21 May 2022 14:23 #243475
by jurod
I have python installed:
(screenshot python.png)
(screenshot linuxcnc.png)
(screenshot Uname-a.png)
If I copy file "linuxcnc.x86_64-linux-gnu.so" from version 2.8.2 to folder "/usr/lib/python2.7/dist-packages" in version 2.9.0, the GUI will run from the Position Logger, but without a link to Linuxcnc hal.
(screenshot Pos Log.png)
(screenshot Files.png)
21 May 2022 14:34 #243477
by jurod
Used folders:
(screenshot path to files.png)
Insight to file .so in 2.8.2:
(screenshot From 2_8_2.png)
Insight to file .so in 2.9.0:
(screenshot From 2_9_0.png)
11 Jul 2022 16:14 #247082
by jurod
small success
I changed the emclog.py interpreter
was: #! /usr/bin/python
is: #!/usr/bin/python3
next
was: if sys.version_info[0] > 2:
raise Exception("Python 2 is required.")
is: if sys.version_info[0] > 3:
raise Exception("Python3 is required.")
etc...
I created a file for future .deb package creation
I added "md5sums" to the file:
1a14c073dc90e29563d3b1c7cfa3b10b usr/lib/python3/dist-packages/ConfigParser.py
to my future .deb package "usr/lib/python3/dist-packages/" file ConfigParser.py (I copied from /usr/lib/python2.7 + definitely adjustments)
I changed in the "control" file:
Installed-Size: 56
Depends: python3
Section: base
and in file "Position Logger.desktop" :
Icon=/usr/share/linuxcnc/linuxcncicon.png
and I created new .deb packages "emclog_1.0.0_all.deb"
I tested on LinuxCNC Bookworm.
next
etc...
Installed-Size: 56
Depends: python3
Section: base
11 Jul 2022 22:11 #247108
by JT
JT
Replied by JT on topic Axis Position Logger
Please start an issue at github.com/jethornton/emclog/issuesHi, please help.
I can't install your Position Logger correctly in master version 2.9.0.
The installation process will run correctly, but unable to start Logger.
hcnc@IS7XM:~$ sudo dpkg -i /home/hcnc/emclog_1.0.0_all.deb [sudo] heslo pre uzivatela hcnc: (spusta sa databaza ... momentalne je nainstalovanych 100440 suborov alebo adresarov. Preparing to unpack .../home/hcnc/emclog_1.0.0_all.deb ... Unpacking emclog (1.0.0) over (1.0.0) ... Nastavuje sa balík emclog (1.0.0) ... Processing triggers for desktop-file-utils (0.23-4) ... Processing triggers for mime-support (3.62) ... Processing triggers for man-db (2.8.5-2) ... hcnc@IS7XM:~$ Error from terminal: hcnc@DELL9010:~$ emclog Traceback (most recent call last): File "/usr/bin/emclog", line 9, in <module> import linuxcnc ImportError: No module named linuxcnc hcnc@DELL9010:~$
JT
11 Jul 2022 22:12 #247109
by JT
JT
Or create a pull request at github.com/jethornton/emclog/pullssmall success
next
etc...
Installed-Size: 56
Depends: python3
Section: base
JT
Time to create page: 0.172 seconds
